1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Blog Mushrooms' Paradise #8. Additional tools for RPI troubleshooting.
  • Author Author: ilvyanyatka
  • Date Created: 30 Dec 2020 2:44 AM Date Created
  • Views 860 views
  • 1meterofpi
  • raspi
  • 1 meter of pi
  • 1 meter of pi - design challenge
  • raspberry pi
  • mushrooms' paradise
  • growing mushrooms
ilvyanyatka
ilvyanyatka
30 Dec 2020
The whole Mushrooms' Paradise blog
    • The Wiring Pi package
    • GPIO Utility
    • Allow connection to PI desktop GUI without monitor
The Wiring PI package contains the GPIO utility which I can use from  the Terminal to debug wiring issues.
The Wiring Pi package was not installed with my PI by default, so I needed to install it manually. Instructions to do so can be found here: wiringPi updated to 2.52 for the Raspberry Pi 4B. Basically the commands to be run from Terminal are:
cd /tmp
wget https://project-downloads.drogon.net/wiringpi-latest.deb
sudo dpkg -i wiringpi-latest.deb
GPIO Utility
Documentation for  the GPIO utility is here: The GPIO utility. All I really need are the commands.
3gpio readall
To see the state of GPIOs
gpio -g mode <pin> out
To set up the pins as output
gpio -g write <pin> 0/1
To change the pin’s signal
By default you cannot connect to Raspberry Pi desktop GUI if monitor is not connected. To allow the without monitor one need to:
Run
sudo raspi-config
And change the following options in the config window:
System Options -> Boot Auto-Login -> select "Desktop Auto Login"
Display Option -> Resolution -> (set whatever resolution other than default)
Interface Options -> VNC -> Yes
