1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Blog water heat sink
  • Author Author: cquent
  • Date Created: 16 Mar 2022 8:20 PM Date Created
  • Views 2311 views
  • Comments 7 comments
water heat sink
cquent
cquent
16 Mar 2022
Hello,
I want to size a water heat sink to dissipate the power of 16 MOSFET transistors of 300W each.
I would like to do this study to compare it to a finned radiator with fan.
However, I don't know how to go about it.
Can you help me?
Thank you
  • cquent
    cquent over 4 years ago
    Hello,
    These are 16 MOSFET transistors of the IXTN22N100L type.
    The 16 transistors are in a drawer of an ATE test rack. it is currently used with a fin and fan disabled. but I would like to find a way to replace the fan and serve fin with a water thermal plate. For the closed circuit with water this is not a problem there are cold groups. What interests me is how to determine by calculation the water thermal plate. What are the thermal parameters to consider?
  • cquent
    Hello,
  • cquent
    cquent over 4 years ago in reply to cquent
    Hello,
    dougw over 4 years ago in reply to cquent
    Water Cooling Calculator
    http://www.nessengr.com/technical-data/water-cooling/
  • cquent
    cquent over 4 years ago in reply to dougw
    Thanks Doug.
    I have also heard that there are heat sink solutions with Peltier modules or even heat pipes.
    Is it true that the Peltier module has low efficiency?
    Is a heat pipe plate possible in an ATE rack drawer?
    dougw over 2 years ago in reply to cquent
    Yes Peltier coolers are very inefficient.
    Heat pipes transport heat from one place to another, but you still have to have a way to cool off the heat pipe.
