1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Forum Is it necessary to publish the blogs in Design Challenge>1meterof Pi Space for sponsored challengers?
  • Answers 2 answers
  • Subscribers 4 subscribers
  • Views 1154 views
surbhika
surbhika over 6 years ago
Hi e14phil, I have published my first entry of the Blogs in my own Blog Space with tag 1 Meter of Pi . But I see that you have created all the challengers a separate Author Space.
Am I supposed to publish all the blogs there and re-publish the already published one?
  • e14phil
    e14phil over 6 years ago +2 suggested
    Hey, surbhika yes, Please post in 1 Meter of Pi space. Thank you for helping gam3t3ch If you have any problems at the end, just message and ill make sure your blogs are counted correctly thanks Phil
  • surbhika
    surbhika over 6 years ago in reply to gam3t3ch +1
    Thank you gam3t3ch . It worked. I shifted the blog place.
  • gam3t3ch
    0 gam3t3ch over 6 years ago
    you should be able to tag your post with something along theses lines and should show up
    raspberry_pi, design challenge, raspberry pi 4 2gb, 1 meter of pi, 1_meter_of_pi, 1 meter of pi - design challenge
    As a non sponsored applicant adding the tags will makes sure they are noticed but after looking if you go to edit you can go to your settings and change its location as well so for example.
    instead of personal blog you can select above it and choose the space to publish in and should be able to find the one meter of pi design challenge in there hopefully that should get it over to the the group.
  • surbhika
    0 surbhika over 6 years ago in reply to gam3t3ch
  • e14phil
    0 e14phil over 6 years ago
    Hey,surbhika  yes, Please post in 1 Meter of Pi space.
    thanks
    Phil
