1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Documents 1 Meter of Pi - Meet the Challengers
  • Author Author: e14phil
  • Date Created: 1 Oct 2020 6:01 PM Date Created
  • Last Updated Last Updated: 8 Feb 2021 5:06 PM
  • Views 6107 views
  • Likes 18 likes
  • Comments 69 comments
1 meter Pi challenge profile
1 Meter of Pi Design Challenge
About this Challenge | Dates | The Judges | The Kit | The Prizes | Technical Resources | Example Application | Terms & Conditions | The Challengers | The Winners
Welcome to the 1 Meter of Pi Design Challenge!
As your rocket ship blasts into space, speeding to Mars, you have 1m3 of space to grow your food and nutrients for the journey. Resources are limited, and you need to make it work!
Luckily, your friends at the Community have provided 25 successful applicants with a Raspberry Pi 4 2GBRaspberry Pi 4 2GB, a Pimoroni PIM487 Automation HAT, PIM486 Enviro HAT, and a PICO HAT Hacker PCB to help them prepare their 1m3 builds. You have 10 weeks to save your crew.
This could be the 1m3 of space on your rocket, or it could be used to feed the masses, or in an urban setting to help feed the needy during a global disaster.
25 successful applicants will get the Challenge Kit free of charge to build and blog their project.
The Dates
Project Phases
Dates
Applications Open17th August 2020
Applications Close (about 1 Month)14th September 2020
Challengers Announced14th October 2020
Projects Due5th January 2021
Winners Announced
Jan 2021
Prizes ShippedJan 2021
Please join us in congratulating the official sponsored Challengers!
We look forward to reading all of their initial blogs and introducing their project designs. You can follow along with the challengers using the links below, as they create more blogs over the coming weeks.
ajayvishaal |  amgalbu | blockheadcoding | cbohra00627 | crisdeodates |  coderdojostpaul2 |  dules | feiticeir0 |  ilvyanyatka | jduchniewicz |  jissdeodates |  karthickiot | kurama007 | milosrasic98 | moi8765 |  nikki14 | nilutpol_kashyap | raspberrypitechguy | rockcacti | skruglewicz | stevotech |  surbhika | ujjwalrathod00700 |  vidyamohanan | vishwasn
ajayvishaal Ajay - IN
The Savior
amgalbu Ambrogio - IT
Gr0G
blockheadcoding Aaron - USA
Autonomous Rotating Farm Pod
cbohra00627 Chinmay - IN
Feeder Container
crisdeodates Cris - IT
Autonomous Cultivation
coderdojostpaul2 Anil - USA
Rest in Pest
dules Davor
Aquaponics Box
feiticeir0 Bruno - PT
Space Vegetables
ilvyanyatka Victoria - USA
Mushroom Paradise
jduchniewicz Jakub - PL
Envidrawer
jissdeodates J. Joseph - IN
Autonomous Pest and Decay Management
karthickiot Karthick - IN
AI Plant Monitor
kurama007 Satoshi - USA
360 Degree Micro Gravity Garden
milosrasic98 Milos - SB
Robot Assisted Garden
moi8765 Moinak - IN
Pi-Ski-Farmer
nikki14 Nikira
Edible Algae system
nilutpol_kashyap Nilutpol - IN
Raspberry Pi Hydroponics
hugohu Hugo - US
Food on Mars
rockcacti Anthony - USA
The Space Salad System
skruglewicz Steve - US
Edible Algae
stevotech Ian - UK
Raspberry Pi Farm
surbhika Surbhika - IN
Spirulina Farming In SPACE
embeddedguy Ujjval - DE
Automation for Lighting plants in Space
vidyamohanan Vidya - IN
Portable Oxygen Generator
vishwasn Vishwas - IN
Agrocube
Interested in joining the Challengers? You can do it as a non-sponsored Challenger! Here's how:
Simply purchase the Raspberry Pi 4 2GBRaspberry Pi 4 2GB, integrate it into your project, keep the space requirements under 1m3 and post 10 blogs about your design journey in the 1 Meter of Pi space (tagging your blogs ' 1meterofpi ') and you'll be eligible to win the awesome prizes.
Read full terms & conditions for more details.
Good Luck Everyone!
  • 1meterofpi
  • 1meter of pi
  • challenger list
  • raspberry_pi_design_challenge
    dougw over 6 years ago +9
    Congratulations challengers and good luck - it is going to be a short growing season...
  • danzima
    danzima over 6 years ago +8
    Hello to all challengers for 1 Meter of Pi! Due to some issues sourcing 25 of each part and the fact that I'm only able to go into our office 1-2 times per week due to COVID, we are delayed on shipping…
  • e14phil
    e14phil over 5 years ago +8
    Hello, just a quick update to say the winners announcement is being put together right now, you all produced so so many projects blogs that we are all reading! We will be back with you all shortly. (and…
  • cbohra00627
    cbohra00627 over 5 years ago
    My Raspberry Pi is not booting up. When I connect it to power supply, the red led works fine but the green led (ACT indicator) is not flashing. It just remains solid green. It was working fine till yesterday.
    Even after removing the SD card and then connecting to power supply, the ACT indicator remains green.
    Does anybody know why is this so?
  • cbohra00627
  • moi8765
    moi8765 over 5 years ago in reply to cbohra00627
    It seems I have the same issue. And I thought I was the one not doing it properly. I have purchased and tried with 4 microSD cards. My Pi just dosent boot up
  • gam3t3ch
    gam3t3ch over 5 years ago in reply to cbohra00627
    Seems to be a common issue right now are you using the pi imager downloader?  I would try downloading the iso and then using etcher to copy the image to a sd card and then it should be good.
    head over to '
    https://www.raspberrypi.org/software/operating-systems/
    and then use
    https://www.balena.io/etcher/
    hope it helps.
  • cbohra00627
    cbohra00627 over 5 years ago in reply to cbohra00627
    Well, the issue got solved when I ran the EEPROM recovery tool. My problem started when there was a sudden power cut while the ACT indicator was still lit.
    I searched online and performed the following steps:
    1. Ran the EEPROM recovery tool.
    2. Formatted the SD card and flashed the image again.
    Its working fine now.
    Thanks!
  • cbohra00627
    I am again facing the same problem. I think the problem starts after I run the command to upgrade it.
    I got many errors while trying to upgrade it.
  • hugohu
    hugohu over 5 years ago in reply to cbohra00627
    Is it a problem with the batch?
    I have 2 pi's, 4GBs, from before that are opened and another 2(given 2GB and another 4GB), unopened, and I don't face any issues with those.
  • cbohra00627
    cbohra00627 over 5 years ago in reply to hugohu
    Well, I don't think its the problem with pi, maybe it is because of handlingimage.
    Actually, there was a sudden power cut while I was upgrading the Pi, the first time. So, I reformatted the SD card, again flashed and started upgrading it again.
    The second time when it didn't boot, I realized that maybe its not because of power cut. Actually, I am interacting with my Pi via SSH i.e wireless. Whenever I tried to upgrade it, I got some errors, maybe because of broken files or something else, I don't know. After encountering these errors, I was enable to use the terminal anymore. I got this error when I tried to run any command: "/bin/ls: .: Input/output error". After getting this kind of error, what I used to do is that I directly turned off the power supplyimageimageimage (there was no other option). I think this is the reason for the failure.
    Also, as far as I remember this used to happen when some kind of kernel image settings were happing on the terminal. When I encountered my problem (both the times), I think this was happening on the screen: "Adding something.image to ......kernal.....". I think that is why the pi is unable to boot.
    I think I will just buy a HDMI cable and again set it up (with wireimage).
    Thanks!
  • hugohu
    I'm always too lazy to edit config files, and instead decide to take an even harder route of connecting a keyboard, my DSI display, setting up wifi, reboot, and then using SSH.
    *shrugs*
    Power cut? At most, that would ruin EEPROM.
    *grimaces*
