At The Core Design Challenge
  • At The Core Design Challenge
Forum how to include 'cy_retarget_io.h' into our project?
Join At The Core Design Challenge to participate - click to join for free!
  • Subscribers 51 subscribers
  • Views 1955 views
Sudeep AJ
Sudeep AJ over 3 years ago
So currently I am experimenting with HAL UART APIs and I learnt that there is cy_tetarget_io which helps us to use printf function with UART. I used it with the example project provided and it worked perfectly. But when I tried to include it in my Empty Project I am getting an fatal error. Can anyone please help me with this issue?
  • misaz
    misaz over 3 years ago in reply to misaz +5 verified
    Here it is with picture. At first you need to select project to include library. Open any source file in the project. Remember than in case of dual core app there are two projects. Select project in which…
  • misaz
    misaz over 3 years ago +1
    You need to open Library Manager tool and include (mark checkbox) retarget_io library to your project. In demo project it is included but in some templates (for example empty project) it is not included…
  • misaz
    0 misaz over 3 years ago
    You need to open Library Manager tool and include (mark checkbox) retarget_io library to your project. In demo project it is included but in some templates (for example empty project) it is not included by default.
  • misaz
    +1 misaz over 3 years ago in reply to misaz
    Here it is with picture. At first you need to select project to include library. Open any source file in the project. Remember than in case of dual core app there are two projects. Select project in which you want to use printf. Then open Library Manager as indicated in previous post:
    Then click Add Library button:
    Then mark retarget-io in Peripherals section and confirm by OK.
    Then confirm Previous dialog by Update button.
    • Vote Up +5 Vote Down
  • Sudeep AJ
    0 Sudeep AJ over 3 years ago in reply to misaz
    Thank you very much for the help!
