BeagleBone Black Radio Challenge
  • BeagleBone Black Radio Challenge
Blog Beaglebone Black Radio challenge - First step(setting up SDR)
  • Author Author: Nitin_Bhaskar
  • Date Created: 16 Feb 2014 12:57 PM Date Created
  • Views 1654 views
  • beaglebone_black
  • sdr
  • beaglebone_black_radio
Nitin_Bhaskar
Nitin_Bhaskar
16 Feb 2014
Thanks element14 for selecting my design for Beaglebone Black Radio Challenge. I own a Beaglebone(first generation) so i have some prior experience in handling this new beauty(BBB).
My project aims in designing a radio using SDR and internet. The radio's interface(GUI) shall be Qt/GTK based. Provision of searching, storing and recording of channel shall be added. The audio output is using a USB sound card. The initial step is make RTL_SDR talk to Beaglebone Black.
Building rtl-sdr software
First, install cmake and libusb on Beaglebone by running
opkg install cmake
opkg install libusb*dev
Check out the rtl-sdr source and build it as described below,
git clone git://git.osmocom.org/rtl-sdr.git
cd rtl-sdr/
mkdir build
cd build
cmake ../
make
sudo make install
This completes the installation. Now its time to test it by running
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib rtl_test -t
Below is output i  got,
Found 1 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R820T tuner
Supported gain values (29): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
Sampling at 2048000 S/s.
No E4000 tuner found, aborting.
Success!!!!!
My next step would be to get usb audio to work. Looks like I have to disable HDMI output for this.
    shabaz over 12 years ago +1
    Hi Nitin, Great stuff! And glad you're documenting it step-by-step. Looking forward to trying this out too. I've only tried the SDR dongle on Windows so far. (by the way a carriage-return is missing before…
  • Nitin_Bhaskar
    Nitin_Bhaskar over 12 years ago in reply to onebeartoe +1
    Hi Roberto, My next post will be on that!!!! -Nitin
  • onebeartoe
    onebeartoe over 12 years ago
    Nice post, Bhaskar!
    Last night I followed your steps to setup rtl_test, with the Adafruit radio antenna attached.
    I am super new to rtl and eventually found the rtl_fm command.  I tried different combinations of rtl_fm piped to sox and aplay, but was only successful in hearing radio static from the speakers.
    Can you provide some guidance on how to issue an rtl command to play FM frequency 104.5, and output the sound to speakers?
    Thanks,
    Roberto
  • Nitin_Bhaskar
    Hi Roberto,
    -Nitin
  • Nitin_Bhaskar
    Hi Roberto,
    -Nitin
