BeagleBone Black Radio Challenge
  • BeagleBone Black Radio Challenge
Forum BBB- camera interfacing
  • Subscribers 3 subscribers
  • Views 1412 views
i am working with image processing on BBB. i am little confuse in camera selection that which camera will be more compatible to use with BBB.for capturing images i m thinking to use 'OV9655' camera but i am not sure about it. can anyone suggest me better option or any other camera?
  • clem57
    0 clem57 over 10 years ago
    Well in general that is a good choice. But to suggest one, you need to tell more on expected use and application areas. More parameters you give, the better suggestion.
    Clem
    0 e14 Contributor over 10 years ago in reply to clem57
    basically, i have to do camera interfacing with 3 cameras on bbb under linux which will capture the images of three different objects. but initially i have to focus on only one camera. so while deciding any suitable camera i have to keep this in mind that what ever i select for one, i have to do that with remaining two also.
    i have found some more cameras but when i think about the three camera interfacing then i get confused. like, one camera that i found was "LI-LBCM3M1 Leopard Imaging"
    it has 32 output ports. so for using one might be possible but when 3 cameras are concerned then it will create problem cx bbb dont have too much ports for this.
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    To use them at the same time would require a board for each basically. Microprocessors have limited bandwidth to I/O when you run them with Linux because of real time requirements hard to meet. But you could dedicate a micro-controller to each and tie to a single microprocessor for all 3 using a high speed UART or I2C.
    Clem
    ok.. thats might be good approach. i have also heard about gpmc(general purpose memory controller) interface. they are also use to transmit capture images from camera to beagle but i am unable to find its tutorials thats why don't have too much detail about them.what do you think about it?
  • clem57
    mk.
    From what I can tell, these are for  Dual-Port SRAMs only which ultimately may apply. But there are many proposals in the world, few truly become standards. This fails the mustard. Focus on well supported things. You have given no reason for 3 different objects. Are they rooms or a museum piece? Security? Purpose could determine hardware resources.
    clem57
    PS why is this post in beagle bone radio Internet? Anything to do with your purpose?
