Blog Bluetooth Unleashed : AAPSAD #10 : The Super Power
  • Author Author: sakthi.1260
  • Date Created: 3 Jul 2018 1:17 AM Date Created
  • Views 789 views
  • raspberry_pi_3_model_b_plus
  • bluetooth unleashed
sakthi.1260
sakthi.1260
3 Jul 2018
Hello guys,
This week on Bluetooth Unleashed...
We are done with the control unit! A few small things are pending for now and GUI is complete now.
One big thing we've been waiting for...
Unleashing the power of Bluetooth....
Although I had multiple options with Bluetooth to be used on the Arduino side (choices were HM11, Ti CC2650, nRF51822)
but I found a lot of HC-05 laying around (once we used to add this to everything) so thought of putting them to use.
Initially there was a lot of trouble with serial port emulation over Bluetooth, it was discoverable, got paired but it always ended up a connection failure.. and finally
something happened
Blueman bluetooth manager and pyserial made life easy, a few clicks and everything was smooth.
and this time I brought the Arduino Micro into the scene and everything worked like a charm.
A set of charterers and a switch case on the arduino side will controll the GPIOs
The completed Arduino code:
#include <TroykaDHT.h>
#include <SoftwareSerial.h>
#define ROOM_SUM 11
#define ROOM_CIT 12
#define HUMIDIFIER 2
#define FAN 4
#define LIGHT 5
#define BRX 9
#define BTX 10
#define LIGHT_SENSE A0
void off_all()
  digitalWrite(HUMIDIFIER,LOW);
  digitalWrite(FAN,HIGH);
  digitalWrite(LIGHT,HIGH);
void freshner (int fresh)
    digitalWrite(fresh,HIGH);
    delay(750);
    digitalWrite(fresh,LOW);
DHT dht(8, DHT11);
SoftwareSerial btserial(BRX, BTX);
int hum;
float temperature;
char bdata;
void setup()
   pinMode(HUMIDIFIER, OUTPUT);
   pinMode(ROOM_SUM, OUTPUT);
   pinMode(ROOM_CIT, OUTPUT);
   pinMode(FAN, OUTPUT);
   pinMode(LIGHT, OUTPUT);
   btserial.begin(9600);
   dht.begin();
void loop()
  dht.read();
  delay(100);
  hum = dht.getHumidity();
  temperature = dht.getTemperatureC();
  int lux;
  if (btserial.available()){
   bdata=btserial.read();
   Serial.println(bdata);
   switch(bdata){
    case 'a' : //Auto
      off_all();
      lux = analogRead(LIGHT_SENSE);
      if (lux < 100)
          digitalWrite(LIGHT,LOW);
      break;
     case 'b': //ANGER
         if (hum<80)
              digitalWrite(HUMIDIFIER,HIGH);
         if (temperature>26)
              digitalWrite(FAN,LOW);
         freshner(ROOM_CIT);
         //delay(480000);
         break;
      case 'c':             //SAD
        if (hum<60)
        if (temperature>26)
        freshner(ROOM_SUM);
        //delay(480000);
        break;
       case 'd':             //JOY
         if (hum<60)
         if (temperature>26)
         freshner(ROOM_CIT);
         //delay(480000);
         break;
       case 'e': //MANUAL
          off_all();
          break;
       case 'f':
          break;
       case 'g':
          break;
       case 'h':
          break;
       case 'i':
          break;
       case 'j':
          break;
       case 'k':
          break;
       case 'l':
          freshner(ROOM_SUM);
          break;
       case 'm':
          freshner(ROOM_CIT);
          break;
       default:
          break;
to be continued....
Cheers image
