Blog Audio Module and placement of push button
  • Author Author: roborob1266
  • Date Created: 4 Aug 2018 3:52 AM Date Created
  • Views 2643 views
  • adxl335eb
  • adafruit vs1053 mp3 player
  • 5" touch screen
  • arduino mkr
  • design for a cause - design challenge
  • sd
roborob1266
roborob1266
4 Aug 2018
Hello everyone!
I received my Adafruit MP3 Shield yesterday late and was able to solder the connectors and test my Wav files! Worked like a champ with the speakers I took from a broken laptop.
I also was able to finish the boxes on the TFT display as the place holder for the images that will be displayed this past week since I last updated!
Tomorrow, I will work on touch button options for each box place holder. I have the dimensions and coordinates for each box that will be on the screen.
I will also put image files on the SD card then test out the SD card reader on the MP3 player. If I can access that then I don’t have to worry about converting to Hexadecimal and writing to the eeprom. I will just reference image 1 for the first spot and image 2 for the next one and so on. I formatted each image to fit within the boxes so they should all be fine.
I will see if JPG is smaller than PNG and go with the smaller size files.
I am also going to incorporate the ADXL335 accelerometer that was supplied so I could detect when my son picks up the device and that will send a signal to wake up the device. I am going to research how I can make this go down to low power mode to save on power.
I wasnt feeling too good today but I pressed through once the migraine subsided!
I will update soon with images, code and part numbers!
  • aspork42
    aspork42 over 8 years ago +1
    Nice. I've done one low-power (battery) project. It was fun to try all the different tricks to save juice. Good luck!
    jw0752 over 8 years ago +1
    I hope you are feeling better John
  • prashanth.nagendrappa
    prashanth.nagendrappa over 8 years ago
    Super
    Super
