Blog Design for a Cause - Smart Voice Synthesizer, Visualizer- Audio Interface - Independence Day Special
  • Author Author: prashanth.nagendrappa
  • Date Created: 15 Aug 2018 3:09 PM Date Created
  • Views 1857 views
  • Comments 6 comments
  • element 14
  • amplifer
  • audio jack
  • arduino mkr
  • design for a cause - design challenge
15 Aug 2018
#Blog5
Hello Everyone!
Happy Independence Day image
Its August 15, we celebrate Independence Day in our country.
Here is my work on integrating SD Card Shield and PAM8403 Audio Amplifier to Arduino MKR1000. Which is the part of  "Smart Voice Synthesizer, Visualizer".
As per the design, the hand Gestures will be transformed into voice where this implementation play the key role.
Components Required
  • Arduino MKR1000
  • Arduino UNO shield
  • Arduino MKR1000 SD Card Shield
  • PAM8403 Audio Amplifier Module
  • Jumper Wire
  • Speaker
  • SD Card
The Circuit
Connect the SD card shield to connect Arduino MKR1000 and Audio Amplifier
SD Card should contain test.wave audio file.
Demo
Independence Day special
“ Saare Jahanse Accha…….image”
The Code
#include <SD.h>
#include <SPI.h>
#include <AudioZero.h>
void setup()
  // debug output at 115200 baud
  Serial.begin(115200);
  // setup SD-card
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println(" failed!");
    while(true);
  Serial.println(" done.");
  // 44100kHz stereo => 88200 sample rate
  AudioZero.begin(16000);
void loop()
  int count = 0;
  // open wave file from sdcard
  File myFile = SD.open("test.wav");
  if (!myFile) {
    // if the file didn't open, print an error and stop
    Serial.println("error opening test.wav");
    while (true);
  Serial.print("Playing");
  // until the file is not finished
  AudioZero.play(myFile);
  Serial.println("End of file. Thank you for listening!");
  while (true) ;
Stay Tunedimage
Thank You!
    genebren over 8 years ago +2
    Nice update on your design challenge project. The sound system seemed to be crisp and clear. Keep up the good work. Gene
  • prashanth.nagendrappa
    prashanth.nagendrappa over 8 years ago in reply to genebren +2
    Thank You genebren Sir
    jw0752 over 8 years ago +2
    Happy Independence Day. I enjoyed hearing the audio of your project work. You are off to a great start. John
    Gene
