Blog Seeing EyeDuino - Blog #5 - Robot code
  • Author Author: dwinhold
  • Date Created: 10 Aug 2018 12:06 PM Date Created
  • Views 1176 views
  • mkr_1000
  • braille
  • robot
  • eyeduino
  • dwinhold
  • code
  • design for a cause - design challenge
dwinhold
dwinhold
10 Aug 2018
For my 5th blog posting I will show the code I am using to run the robot and spelling in Braille. This part has been a bit of work but is coming along great. I have run into issues with the motors I have for driving the robot but that will be discussed in my next blog.
Below is the code (so far) for driving the robot. The Braille code hasn't been added in as of yet but the alphabet has been coded.
#include <Servo.h>
Servo myservo;
//Drive Motors
const int MotorR1 = 6; //forward right motor
const int MotorR2 = 7; // backward right motor
const int MotorL1 = 4; // forward left motor
const int MotorL2 = 5; // backward left motor
//Ultrasonic Sensor
const int trigPin = 9;
const int echoPin = 10;
long duration;
int distanceL;
int distanceF;
int distanceR;
int pos = 0;
void setup() {
  //Ultrasonic Sensor
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  Serial.begin(9600);
  //Drive Motors
  pinMode(MotorR1, OUTPUT);
  pinMode(MotorR2, OUTPUT);
  pinMode(MotorL1, OUTPUT);
  pinMode(MotorL2, OUTPUT);
  digitalWrite(MotorR1, LOW);
  digitalWrite(MotorR2, LOW);
  digitalWrite(MotorL1, LOW);
  digitalWrite(MotorL2, LOW);
  myservo.attach(8);
  //Braille
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  int timeA = 200;
  int timeB = 300;
  int timeC = 500;
void loop() {
  for (pos = 30; pos <= 90; pos += 1) { //Send servo to start position and turn to face forward
    // in steps of 1 degree
    myservo.write(pos);
    delay(15);
  //Ping and record distance
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distanceF= duration*0.034/2;
  for (pos = 90; pos <= 150; pos += 1) { //Turn to far right
    myservo.write(pos);
    delay(15);
  distanceR= duration*0.034/2;
  for (pos = 150; pos >= 90; pos -= 1) { //Return to forward position
    myservo.write(pos);
    delay(15);
  for (pos = 90; pos >= 30; pos -= 1) { //Move to far left position
    myservo.write(pos);
    delay(15);
  distanceL= duration*0.034/2;
//With ping distance information decide how to proceed
if (distanceL <= 600 && distanceL > 400)
  //Add braille code here with warning
        //turn right
        digitalWrite(MotorR2, HIGH);
        digitalWrite(MotorL1, HIGH);
        delay(500);
  if (distanceL <= 400)
        //turn right
        delay(750);
    if (distanceR <= 600 && distanceR >400)
      //turn left
      digitalWrite(MotorR1, HIGH);
      digitalWrite(MotorL2, HIGH);
      delay(500);
  if (distanceR <= 400)
      //turn left
      delay(750);
  if (distanceF >= 800)
      //go forward
      delay(2000);
  if (distanceF < 800 && distanceF > 600)
      //go forward
      delay(1000);
  if (distanceF < 599 && distanceF > 300)
      //go forward
      delay(500);
  if (distanceF < 300)
      //Stop
      delay(1000);
Below is the code I will be using for the Braille. I still have to decide what the warnings will say before it is added into the above code.
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  int timeA = 200; //delay between on and off
  int timeB = 300; //delay between Letters
  int timeC = 500; //delay between Words
  //A & 1
  digitalWrite (1, HIGH);
  delay(timeA); //delay between on and off
  digitalWrite(1, LOW);
  //B & 2
  digitalWrite (3, HIGH);
  digitalWrite (1, LOW);
  digitalWrite (3, LOW);
  //C & 3
  digitalWrite (2, HIGH);
  digitalWrite (2, LOW);
  //D & 4
  digitalWrite (11, HIGH);
  digitalWrite (11, LOW);
  //E & 5
  //F & 6
  //G & 7
  //H & 8
  //I & 9
  //J & 0 (zero)
  //K
  digitalWrite (12, HIGH);
  digitalWrite (12, LOW);
  //L
  //M
  //N
  //O
  //P
  //Q
  //R
  //S
  //T
  //U
  digitalWrite (13, HIGH);
  digitalWrite (13, LOW);
  //V
  //W
  //X
  //Y
  //Z
Any questions, comments or ideas is always welcome
Dale Winhold
  • dixonselvan
    dixonselvan over 8 years ago +2
    Thanks dwinhold for sharing the code. But the code looks quite lengthy which could be reduced if you try to find out the repetitive pattern and pass the values to a function. Something like this, if (distanceL…
  • aspork42
    aspork42 over 8 years ago in reply to dixonselvan +2
    I was thinking you could write a similar routine for each of the letters in the alphabet. They could be stored as an array and passed to a function which does all the digital Writes. Something like below…
  • dixonselvan
    1. if (distanceL <= 600 && distanceL > 400)
    2.     {
    3. //Add braille code here with warning
    4. //turn right
    5.         digitalWrite(MotorR1, LOW);
    6.         digitalWrite(MotorR2, HIGH);
    7.         digitalWrite(MotorL1, HIGH);
    8.         digitalWrite(MotorL2, LOW);
    9.         delay(500);
    10.         digitalWrite(MotorR1, LOW);
    11.         digitalWrite(MotorR2, LOW);
    12.         digitalWrite(MotorL1, LOW);
    13.         digitalWrite(MotorL2, LOW);
    Could be changed to,
    If (condition)
      motorWrite (LOW, HIGH, HIGH, LOW);
      delay(500);
      motorWrite (LOW, LOW, LOW, LOW);
    void motorWrite (val1, val2, val3, val4)
       digitalWrite(MotorR1, val1);
       digitalWrite(MotorR2, val2);
       digitalWrite(MotorL1, val3);
       digitalWrite(MotorL2, val4);
  • aspork42
    Something like below (This compiles without error but I haven't run it on any hardware):
    void setup() {
      pinMode(1, OUTPUT);
      pinMode(2, OUTPUT);
      pinMode(3, OUTPUT);
    //Create a constant variable for each Braile character
    const bool _Char_A[6] = {1,0,0,0,0,0};
    const bool _Char_B[6] = {1,1,0,0,0,0};
    const bool _Char_C[6] = {1,0,0,1,0,0};
    //remember which output pins we will be using in our For loop
    const int _OutputPins[6] = { 1,2,3,11,12,13};
    void loop() {
      WriteLetter(_Char_A);
      delay(1000);
      WriteLetter(_Char_B);
      delay(1000);
      while(1);
    void WriteLetter(bool letter[])
      // turn pins ON
      for(int n =0; n < 6; n++)
        digitalWrite(_OutputPins[n], letter[n]);
      //wait
      delay(500);
      //turn pins OFF
        digitalWrite(_OutputPins[n], LOW);
  • aspork42
    void setup() {
      pinMode(1, OUTPUT);
      pinMode(2, OUTPUT);
      pinMode(3, OUTPUT);
    void loop() {
      delay(1000);
      delay(1000);
      while(1);
      // turn pins ON
      //wait
      delay(500);
      //turn pins OFF
