Blog SeeingEyeduino - Blog #7 - Assembling the project
  • Author Author: dwinhold
  • Date Created: 21 Aug 2018 12:35 PM Date Created
  • Views 2296 views
  • Comments 7 comments
  • mkr_1000
  • robot
  • dwinhold
  • design for a cause - design challenge
  • seeing eyeduino
dwinhold
dwinhold
21 Aug 2018
Hello everyone,
First, I would like to thank everyone who has been following, reading and leaving feedback. This competition is so important for everyone involved, I hope it will help many people.
This blog is to do with assembling the SeeingEyeduino. In the past week I have made up most of the remaining parts for my project. The Braille finger pad was the most important part of this project. Below are pictures of where I am at, I will explain each photo and give details. If there is anything you have questions, comments or ideas on, please leave a reply. Every little bit helps!!
Please ignore the Monopoly coffee table I took the photos on....... I made it!!
Below is the ultrasonic sensor attached to the servo to check for obstacles ahead.
I attached the Arduino to a breadboard  to make it easier for attaching the wiring. On the other end of the breadboard is the L298 IC motor controller (This may or may not be used at this time as I will probably not be using the drive motors)
Here I have the battery slot to run the Braille pad. It take a 18650 3.7v battery. I also added in a power switch, this will be moved to where you hold onto the SeeingEyeduino for easy access.
As you can see in the next picture I have the handle and Braille pad. Since I don't have a 3d printer I made it out of wood. The actuators go 1/2 mm above the face of the pad. This makes it a comfortable height.
My project is coming close to being finished. Below is a list of what I have left to complete:
  • Rear ultrasonic sensor
  • Complete the coding
  • Test run to make sure everything works as expected
  • Add any extras that may come up for improvement
Thank you for reading
Dale W
    genebren over 8 years ago +2
    Nice update on your design challenge project. Keep up the good work! Gene
  • dixonselvan
    dixonselvan over 8 years ago +2
    Nice progress dwinhold and it is always happy to see things coming the way we expected. Good luck for the remaining part. Just out of curiosity, will the braille system be felt by people's hand? Like if…
  • dwinhold
    dwinhold over 8 years ago in reply to dixonselvan +2
    Hi Dixon, The Braille pad is small, the top third of your index finger size. The actuators are very small and have just enough power to extend all the way. With little force you can push them down, I had…
  • aspork42
    aspork42 over 8 years ago
    Good update - could we get a "zoomed out" picture of the unit?
  • prashanth.nagendrappa
    prashanth.nagendrappa over 8 years ago
    Awesome Update
  • dixonselvan
    dixonselvan over 8 years ago in reply to dwinhold
    That's great dwinhold
  • dwinhold
    Hi Dixon,
    The Braille pad is small, the top third of your index finger size. The actuators are very small and have just enough power to extend all the way. With little force you can push them down, I had it spelling Braille on my finger for around 5 minutes and there was no pain or discomfort at all. This was a concern of mine as well so I tested this out a lot.
    Thank you for the comment and question
    Dale W
  • dixonselvan
    Just out of curiosity, will the braille system be felt by people's hand? Like if they need to keep their hand to understand the full message, will it not be hurting a bit because of the solenoids? Can an arrangement like rubber be placed to reduce the impact?
