Forum Tag for 'Design for a Cause' Design Challenge
  • Answers 2 answers
  • Subscribers 4 subscribers
  • Views 1828 views
  • design for a cause
dixonselvan
dixonselvan over 7 years ago
Can anyone let me know the tag to be used for the design challenge blogs? Is it 'Design for a Cause' tag?
If yes why ain't our blogs not featured in the recent content in the design challenge page? Which is how it usually happens when we include the correct tag.
e14phil, Will we receive separate emails with our project tags to be used in our blogs?
  • e14phil
    e14phil over 7 years ago +3
    Hi Dixon To clarify, I will message all the challengers today with their tags and ask everyone to post directly into Design for a Cause - Design Challenge space. Please make sure your blogs are posted…
  • e14phil
    e14phil over 7 years ago in reply to dwinhold +3 suggested
    Hi Dale, We will be messaging today but we need you to post into the Design for a Cause - Design Challenge not your own space. Hope that helps! Phil
  • dwinhold
    dwinhold over 7 years ago +2 suggested
    Hi Dixon As long as your blog is tagged "Design for a Cause" Design Challenge, I should automatically go in the correct directory on this site. When challengers create a blog, we are automatically tagged…
  • dwinhold
    0 dwinhold over 7 years ago
    Hi Dixon
    As long as your blog is tagged "Design for a Cause" Design Challenge, I should automatically go in the correct directory on this site. When challengers create a blog, we are automatically tagged for the challenge, we have to change the tag if the blog isn't for the challenge.... I think!!!
    Dale W
  • dixonselvan
    0 dixonselvan over 7 years ago in reply to dwinhold
    Thanks, dwinhold
    Though our blogs are in the correct directory as we tagged it correctly and created them from the design challenge page, I usually get a confirmation by looking into the recent contents of the design challenge once. As below you can see this question has been tagged with 'Design for a Cause' and it appears in recent content whereas our blogs don't appear there.
    I can also see a blog in the recent contents, so I assume there is no issue as such ours' is a blog type.
  • e14phil
    0 e14phil over 7 years ago
    Hi Dixon
    Please make sure your blogs are posted directly into the Design for a Cause - Design Challenge space, and NOT your own personal blog space.
    Thanks!
    Phil
  • e14phil
    0 e14phil over 7 years ago in reply to dwinhold
    Hi Dale,
    Hope that helps!
    Phil
  • dixonselvan
    0 dixonselvan over 7 years ago in reply to e14phil
    I'm confused here. When I read the email you had sent it says tag is not required this year. But here you have said that you will message with our tags.
    Posting directly in the Design Challenge is well understood.
    Dixon Selvan
  • e14phil
    0 e14phil over 7 years ago in reply to dixonselvan
    Hi Dixon,
    Now I have sent out the emails, I can clarify that we do not require you to tagg your post this time but it DOES need to be posted in the Design for a Cause - Design Challenge space.
    Tags will not pull a blog post into the correct space.
    I hope that is more clear.
    thanks!
    Phil
