Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog And The Lamp Begins To Look Brighter
  • Author Author: RParkerE
  • Date Created: 29 Apr 2015 1:06 AM Date Created
  • Views 1107 views
  • mini_automator
  • enchanted-objects-design-challenge
  • enchanted-objects
RParkerE
RParkerE
29 Apr 2015
I just received an dimmable LED (LOHAS 20W LED Chip). I plan on running a few test programs, starting with the ones that Infineon provide, while I wait for my recessed can whip extension to arrive and I will start prototyping the lamp.
Here is a picture of the beauty:
I have also been messing around with TinkerCAD to build a case for the Arduino Yún and Infineon RGB Shield, which is also how I will attempt to prototype multiple lampstands. I would also like to thank all who helped me on my last post!
  • RParkerE
    RParkerE over 11 years ago in reply to Workshopshed +1
    This housing is for the Yún with the RGB Shield already attached, so I doubt you would be able to be able to see the LEDs on the Yún anyway. The LEDs from the RGB Shield will extend outward from the shield…
  • Workshopshed
    Workshopshed over 11 years ago in reply to RParkerE +1
    If you are using the opkg package manager to install any new packages onto the Yun, I strongly advise expanding the O/S onto an SDCard before you start installing those.
  • saum
    saum over 11 years ago
    Waiting for the results you get. image
  • saum
