Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog As The Sunsets...
  • Author Author: RParkerE
  • Date Created: 5 Apr 2015 4:18 PM Date Created
  • Views 894 views
  • enchanted_objects
  • mini_automator
  • magic_lamp
As The Sunsets...
RParkerE
RParkerE
5 Apr 2015
As the sunsets on the genie's home, he is curious as to what time it is, since he forgot to buy a clock. Silly him image image. Fortunately he had a smart home, and all he needed was internet for his house to tell him the time! But how? Well just say the magic word, and the genie will show you!
           "I WISH....."
First you have to find the longitude and latitude for where you live. The genie found it would be much easier to use an API that simply used your IP address to give you this!
String findLon() {
    HttpClient clientLon;
    clientLon.get("http://ip-api.com/csv/?fields=lon");
    while (clientLon.available()) {
      lon = clientLon.readString();
    Serial.print("Lon: ");
    Serial.println(lon);
    return lon;
String findLat() {
    HttpClient clientLat;
    clientLat.get("http://ip-api.com/csv/?fields=lat");
    while (clientLat.available()) {
      lat = clientLat.readString();
    Serial.print("Lat: ");
    Serial.println(lat);
    return lat;
Once the genie knows where he is, he now can figure out when the sunsets and rises, using an algorithm that can be found here.
   A = year() / 100;
   B = A / 4;
   C = 2 - A + B;
   E = 365.25 * (year() + 4716);
   F = 30.6001 * (month() + 1);
   JD = C + day() + E + F - 1524.5;
   JC = (JD - 2451545) / 36525;
   longSun = int(280.46646 + JC * (36000.76983 + JC * 0.0003032)) % 360;
   anomSun = 357.52911 + JC * (35999.05029 - 0.0001537 * JC);
   eOrbit = 0.016708634 - JC * (0.000042037 + 0.0000001267 * JC);
   sunEqCtr = sin(D2R * (anomSun)) * (1.914602 - JC * (0.004817 + 0.000014 * JC)) + sin(D2R * (2 * anomSun)) * (0.019993 - 0.000101 * JC) + sin(D2R * (3 * anomSun)) * 0.000289;
   trueLongSun = longSun + sunEqCtr;
   trueAnomSun = anomSun + sunEqCtr;
   sunRadVector = (1.000001018 * (1 - eOrbit * eOrbit)) / (1 + eOrbit * cos(D2R * (trueAnomSun)));
   sunAppLong = trueLongSun - 0.00569 - 0.00478 * sin(D2R * (125.04 - 1934.136 * JC));
   obliqEcliptic = 23 + (26 + ((21.448 - JC * (46.815 + JC * (0.00059 - JC * 0.001813)))) / 60) / 60;
   obliqCorr = obliqEcliptic + 0.00256 * cos(D2R * (125.04 - 1934.136 * JC));
   sunAscen = R2D * (atan2(cos(D2R * (sunAppLong)), cos(D2R * (obliqCorr)) * sin(D2R * (sunAppLong))));
   sunDeclin = R2D * (asin(sin(D2R * (obliqCorr)) * sin(D2R * (sunAppLong))));
   varY = tan(D2R * (obliqCorr / 2)) * tan(D2R * (obliqCorr / 2));
   eqTime = 4 * R2D * (varY * sin(2 * D2R * (longSun)) - 2 * eOrbit * sin(D2R * (anomSun)) + 4 * eOrbit * varY * sin(D2R * (anomSun)) * cos(2 * D2R * (longSun)) - 0.5 * varY * varY *
     sin(4 * D2R * (longSun)) - 1.25 * eOrbit * eOrbit * sin(2 * D2R * (anomSun)));
   haSunrise = R2D * (acos(cos(D2R * (90.833)) / (cos(D2R * (lati)) * cos(D2R * (sunDeclin))) - tan(D2R * (lati)) * tan(D2R * (sunDeclin))));
   if (daylight == true) {
     solarNoon = (720 - 4 * longi - eqTime + -5 * 60) / 1440; //TODO: Change -5 to a method for finding timezone
     solarNoon = solarNoon + .041667;
   else {
   localRiseTime = (solarNoon * 1440 - haSunrise * 4) / 1440;
For sunset all you have to do is manipulate the local rise time to be the local set time by changing it like so:
localSetTime = (solarNoon * 1440 + haSunrise * 4) / 1440;
Unfortunately, this algorithm does not account for daylight savings time, which of course only applies to certain places, but the genie, residing in the US, decided he should account for it.
boolean isDaylightSavings() {
  int marchSecondSunday, novFirstSunday, cent, i, n;
  cent = floor(year() / 100);
  for (i = 8; i <= 14; i++) {
    if (marchSecondSunday != 0) {
      marchSecondSunday = int((i + floor(2.6 * 3 - 0.2) - 2 * cent + year() + floor(year() / 4) + floor(cent / 4))) % 7;
    break;
  for (n = 1; n <= 7; n++) {
    if (novFirstSunday != 0) {
      novFirstSunday = int((i + floor(2.6 * 11 - 0.2) - 2 * cent + year() + floor(year() / 4) + floor(cent / 4))) % 7;
    break;
  if (month() == 3) {
   if (day() >= i) {
     daylight = true;
  else if (month() == 11) {
   if (day() <= n) {
    daylight = true;
  else if (month() > 3) {
   daylight = true;
  else if (month() < 11) {
   daylight = true;
  else {
   daylight = false;
  return daylight;
From here, the genie can also get the current time, and compare the two! and of course his house, the lamp, will shine bright if between the sunset and sunrise!
However, the electrician has not finished at the house, so as of right now, no lights image.
More to come...
  • RParkerE
    RParkerE over 11 years ago in reply to Workshopshed
    I'll definitely give it a look! I know my daylight savings time class is a little heavy haha. Thank you!
  • Workshopshed
    There's a good timezone and daylight saving class from Jack Christiensen https://github.com/JChristensen
