Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Enchanted Objects - Enchanted Clock (Video's)
  • Author Author: dwinhold
  • Date Created: 29 Jun 2015 12:01 AM Date Created
  • Views 1414 views
  • enchanted_objects
  • enchanted_clock
dwinhold
dwinhold
29 Jun 2015
Hi Everyone,
Attached is video of how this all works. I put everything together to work, but without the clock everything couldn't be demonstrated. I set this up in the basement and couldn't have the lasers work the thermostat as we don't have one where I did the demo. Everything works in the demo as you will see. Hope you enjoy:
This is everything until I finish the clock and have it all together. Thank you for your patience and hope you enjoyed. I want to give a very special thank you to my daughter Chrystal (I am now her minion), she taught me a lot.
Dale and Chrystal Winhold
  • dwinhold
    dwinhold over 11 years ago in reply to balearicdynamics +3
    This creation will be completed and used by us. The work that Chrystal and I have put into this has to be finished. The breadboard will be gone and replaced with a PCB to have everything more organized…
  • dwinhold
    dwinhold over 11 years ago in reply to Workshopshed +3
    Thank you Andy, the gears are alot of fun to make. The clock is something I always wanted to make. Dale
  • Workshopshed
    Workshopshed over 11 years ago +1
    Looks like it's all coming together.Those gear wheels look fantastic.
    Dale and Chrystal this is a great job!!! It is my opinion that the value of the projects I see here are not to be saw in an "absolute" way - as it occurs in the industrial world that I don't like so much - but what's happens from the starting point up to where - you in this case - the project has reached. And this is a great creation project. I agree with Andy how the wheels and gears of the clock appears as for a case like this, this is a really value-added. Probably someone think why to make a clock instead of took a one already done... But this is what makes the difference. It is not a "rebuild the world" approach but the creation of something new, that is what should be appreciated in the entire ensemble. All my compliments, the other thing I like is this is a very eclectic creation.
    Do you plan to complete the entire project making is working stable and replace the breadboard with a circuit ?
    Cheers. Enrico
    Cheers. Enrico
  • dwinhold
    This creation will be completed and used by us. The work that Chrystal and I have put into this has to be finished. The breadboard will be gone and replaced with a PCB to have everything more organized. We will be making everything to be part of the clock and not look like it was just slapped together. Thank you so much for your reply, we won't disappoint!!
    Dale Winhold
