Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Genie Lamp [Update]
  • Author Author: RParkerE
  • Date Created: 8 May 2015 7:01 PM Date Created
  • Views 1632 views
  • Comments 6 comments
  • mini_automator
  • enchanted-objects
Genie Lamp [Update]
RParkerE
RParkerE
8 May 2015
So there is no real progress on my project this week unfortunately. Being a high school senior in a residential program is difficult to find the necessary  tools at appropriate times. I have talked to the engineering professors and have begun to set up times in which I will be allowed to use the labs and materials based on my schedule. However, I was able to start a 5 hour print of my enclosure for the Yun and Infineon and RGB. I won't be able to access this enclosure until Monday though. I plan on using the labs next week and finishing up the last leg of my project before I begin working on aesthetics. I just thought I would give everyone an update, and hope the rest of your projects are coming along as well too!
    DAB over 11 years ago +2
    Hi Parker, Get used to finding tools. Every place I worked at had communal tools and you would come to work and find that your test equipment had disappeared over night. Consider it part of the learning…
  • RParkerE
    RParkerE over 11 years ago in reply to DAB +2
    Thank you for the advice, but it really is not finding the tools that I am currently struggling with, rather it is getting permission to use the lab. Since we are teenagers they don't trust us with the…
    Jan Cumps over 11 years ago in reply to RParkerE +2
    When I was a boy it was the same. School would support us doing our own projects in the lab, but were reluctent to leave us alone in there as kiddies (talking first half of the 80's here). We were allowed…
  • Workshopshed
    Workshopshed over 11 years ago in reply to Jan Cumps
    We had limited access to school kit even after hours, there were some after hours clubs but those had predefined projects. I was also 3 miles from the school so I did my stuff mainly at home. I had some old icecream tubs for ferric choloride etching in my bedroom and the inevitable brown stains on the carpet. I do remember using tongs and plastic gloves, having many trips to nuclear power plants and a medical family I'd been shown how to take off gloves so that the chemicals ended up on the inside. I also made a project board and simple continuity buzzer from a 555 timer and loudspeaker (which were cheaper than piezo electric devices at the time)
    When I was a boy image it was the same. School would support us doing our own projects in the lab, but were reluctent to leave us alone in there as kiddies (talking first half of the 80's here).
    We were allowed to use the PCB etching room and the lab equipment when staff was available though. It's in those off-hour times that I learned most of electronics. Thank you, VTIM Diest.
  • RParkerE
    Thank you for the advice, but it really is not finding the tools that I am currently struggling with, rather it is getting permission to use the lab. Since we are teenagers they don't trust us with the equipment without supervision so I am trying to work with the professors and their schedules so I can use the tools. But again, thank you for the advice and heads up.
  • RParkerE
    RParkerE over 11 years ago in reply to Workshopshed
    Fortunately, I have done this. I have all my code on my local computer, a thumb drive, as well as have it on a dropbox server.
  • Workshopshed
    On a similar note, make sure you upload your code somewhere safe in-case the machine you are on crashes or gets moved off to another project.
