Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog MagicHat - 13 - Web interface
  • Author Author: amgalbu
  • Date Created: 15 May 2015 3:48 PM Date Created
  • Views 964 views
  • enchanted_objects
  • javascript
  • websocket
  • magic_doctor_hat
amgalbu
amgalbu
15 May 2015
In this post we will have a look  at how the client side of the web application is implemented
For the web client I used the Angular JS framework and the graphical components made by Telerik. This components are not free (I have a licence since I used those components at work, but they can be easily replaced with free and/or open source components)
The most interesting part is how the web socket is created and how data is processed to update the web page.
The web socket is created by passing the url of thehost we want to connect to (in this case I am using the default IP address of Arduino Yun
                $scope.dataService = new WebSocket('ws://192.168.240.1:3000');
Then, we can add the handlers for the events we are interested in. For example, I am interested to handle the "data received event"
                $scope.dataService.onmessage = function(event){
                       console.log('data ' + event.data);
                       $scope.updateData(JSON.parse(event.data));
Eventually, you could also get notification whenever the connection is open or when an error occurs
$scope.dataService.onopen = function(){
                       console.log('Hello');
 $scope.dataService.onerror = function(){
                       console.log('Error');
The $scope.updateData(data) is a function that takes care of updating the widgets with the data received on the web socket. The JSON.parse(event.data) function creates a Javascript object from the string received. The object structure will look like this
temperature: 37,
pressure: {min: 0, max: 120},
bpm: 62,
pulse: [0,0,0,...,0,0];
This object is passed to the   $scope.updateData function
$scope.updateData = function(data)
 if (data.temperature)
 $("#gauge_temp").data("kendoLinearGauge").value(data.temperature);
 if (data.pressure)
 $("#bpmin-value").val(data.pressure.min);
 $("#bpmax-value").val(data.pressure.max);
 $("#gauge_bp").data("kendoRadialGauge").value(data.pressure.max);
 if (data.bpm)
 $("#read_bpm").each(function() {
        $(this).industrial(data.bpm);
 if (data.pulse)
      if ($scope.pulse.length + (data.pulse.length/10) > 50)
        var howMany = ($scope.pulse.length + (data.pulse.length/10)) - 50;
        $scope.pulse.splice(0, howMany);
 console.log('Adding values..' + data.pulse.length);
 for (var i=0; i<data.pulse.length; i+=10)
        $scope.pulse.push({ value: data.pulse[i] });
The final result is shown in the following video
  • Workshopshed
    There are some great libraries now for coding in Javascript now and that should allow you to spend your time on the hat aspect rather than the UI but still have a great looking dashboard at the end of it.
    We also use lots of Telerik stuff at work, my team are mostly using Knockout rather than Angular but the principles are very similar.
