Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog MagicHat - 21 - Building the hat
  • Author Author: amgalbu
  • Date Created: 20 Jun 2015 9:46 PM Date Created
  • Views 2602 views
  • Likes 8 likes
  • Comments 12 comments
  • enchanted_objects
  • magic_doctor_hat
  • enchanted-objects-design-challenge
amgalbu
amgalbu
20 Jun 2015
This is the last week of the challenge
The hardware and software are almost completed, so it's time to build the real hat. In a previous post, I started building some parts of the hat.
First of all, I cut out from plywood a circle that will be the brim of the hat. I then fixed the blood pressure measurements device to the plywood using some self-tapping screws
Then I covered everthing with a fabric. It's not very fashion, but that's what my mother has in house image
I then attached the brim to the cone that contains all the electronics
You can clearly see the LEDs that make up the mouth and the small speaker
Here is more detailed view of the electronic components inside the hat
Just to recap:
  • Arduino Yun - Atmel side takes care of sampling sensors (temperature, FSR, finger present, pulse)
  • Arduino Yun - Linino side: runs NodeJS, implements Text-To-Speech by invoking a webservice, get Harry Potter-related quotes by invoking a web service
  • Arduino Mini Pro: controls servos and mouth's LEDs
Then I fixed (with some hot glue) the temperature sensor to the baseball cap (trust me: it doesn't hurt when you wear the hat)
Using the same fabric, I cut out a sort of one that covers all the electronic components. Here is the final result
    mcb1 over 11 years ago +2
    Brilliant I was wondering what the final rendition was going to look like and its great. Mark
  • amgalbu
    amgalbu over 11 years ago in reply to mcb1 +2
    Hi Mark thanks, but I think that nothing compared to the quality of the parts created by Andy and Jan as part of their project. That out of my reach (but in terms of tools and of capabilities) Ambrogi…
  • amgalbu
    amgalbu over 11 years ago in reply to balearicdynamics +2
    As we are dealing with engineers, I can tell you this fabric has an interesting feature: the black and white pattern is a real nightmare for every video encoder!!!
  • Workshopshed
    Fantastic! I watched Harry Potter this evening and your hat is far more enchanting than anything I saw in that film
  • amgalbu
    amgalbu over 11 years ago in reply to Workshopshed
    Thanks Andy
    that's very kind of you!
  • amgalbu
    Thanks Andy
