Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Next Road Block
  • Author Author: crjeder
  • Date Created: 13 May 2015 8:52 PM Date Created
  • Views 1097 views
  • smart_key_hooks
  • enchanted_objects
  • infineon_rgb
Next Road Block
crjeder
crjeder
13 May 2015
I've identified an other road block:
The RGB LED Lighting Shield uses 10-bit I2C addresses! I found a good explanation here. Should not be a big problem but standard tools as i2cdetect only work with 7-bit addresses. Let's how it works.
    shabaz over 11 years ago
    Hi!
    You can split it up so that part of the address is sent as the first data byte. Basically, it still all obeys the I2C standard.
    Hi!
