Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Next Road Block
  • Author Author: crjeder
  • Date Created: 13 May 2015 8:52 PM Date Created
  • Views 1073 views
  • smart_key_hooks
  • enchanted_objects
  • infineon_rgb
Next Road Block
crjeder
crjeder
13 May 2015
I've identified an other road block:
The RGB LED Lighting Shield uses 10-bit I2C addresses! I found a good explanation here. Should not be a big problem but standard tools as i2cdetect only work with 7-bit addresses. Let's how it works.
  • Workshopshed
    Looking at the code for i2cdetect it only does 7 bit addresses. It should be possible to tweek that for 10 bit addresses.
    http://www.lm-sensors.org/browser/i2c-tools/trunk/tools/i2cdetect.c
    Alternatively you could look at the code libraries created for the Arduino and swap in the relavent low level commands.
  • Workshopshed
