Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Next Road Block
  • Author Author: crjeder
  • Date Created: 13 May 2015 8:52 PM Date Created
  • Views 1071 views
  • smart_key_hooks
  • enchanted_objects
  • infineon_rgb
Next Road Block
crjeder
crjeder
13 May 2015
I've identified an other road block:
The RGB LED Lighting Shield uses 10-bit I2C addresses! I found a good explanation here. Should not be a big problem but standard tools as i2cdetect only work with 7-bit addresses. Let's how it works.
  • clem57
    clem57 over 11 years ago
    Why a problem? If you see 111110xx or F8 or higher, you probably have a 10 bit address. All 7 bit addresses are in the rang up to F7.
    Clem
  • crjeder
    crjeder over 11 years ago in reply to clem57
    The problem is that not all tools (eg i2cdetect) do work with 10 bit addresses. I have to check if node.is i2c library does support this. If not I have to implement my self which will cost time. Technically it is not a big deal.
  • crjeder
