Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog The Magic Lamp
  • Author Author: RParkerE
  • Date Created: 16 Mar 2015 6:10 PM Date Created
  • Views 1954 views
  • Comments 10 comments
  • enchanted_objects
  • mini_automator
  • iot
The Magic Lamp
RParkerE
RParkerE
16 Mar 2015
Late one night...
You are sitting at your desk, doing your work in the late afternoon. Its a beautiful day outside and your desk is by a door, there is no need for you to have your lights on. But the sun begins to set, and you are stuck in the dark, too immersed in your work to get up and turn on the lights. Fortunately you have a magic lamp! This lamp has the power to know when the sun is setting and turn itself on.
And the Genie granted your wishes...
For a consumer friendly solution to all your lazy problems! The genie, Premier Farnell, poofed in all the tools need and all the workers necessary to turn your wish a reality. His new help toiled day and night until your wish came true. Your lights are now Smart. They will function independent of user input, minus the initial setup, and we will all live happily ever after.
To Be Continued...
  • Workshopshed
    Workshopshed over 11 years ago +1
    Is it going to slowly get brighter or will it use a relay/solid state relay
  • Workshopshed
    Workshopshed over 11 years ago in reply to RParkerE +1
    Sounds good, you could also then use it as an alarm clock for the morning
  • clem57
    clem57 over 11 years ago +1
    Will it work on a cloudy day?
  • Workshopshed
  • RParkerE
    RParkerE over 11 years ago in reply to Workshopshed
    I will be attempting to have it start dim and slowly grow brighter in order not to harm the users eyes and allow his/her to adjust to the lighting.
  • Workshopshed
  • Workshopshed
  • RParkerE
    Workshopshed I will definitely take that into consideration and see what I can do with that!
