Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Forum Materials requirements and limitations...
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 5 subscribers
  • Views 1999 views
How much of the provided kit materials are you required to use?
What are the limitations on using materials not included in the kit?
  • cstanton
    cstanton over 11 years ago +2 suggested
    UVBlue wrote: How much of the provided kit materials are you required to use? As much or as little as your project(s) require to your specification. What are the limitations on using materials…
  • doctorcdf
    0 doctorcdf over 11 years ago
    We would like you to use at least some of the parts from the kit in the solution you build: you are NOT required to use all of them, whatever is deemed suitable for your project.
    The additional budget is provided precisely so you can use materials not included in the kit - there are no particular limitations (having said this, some materials may not be allowed in by your country, those restrictions apply).
  • fvan
    0 fvan over 11 years ago in reply to doctorcdf
    Hi Christian,
    you mention an additional budget is provided, but I can't seem to find any information about it on any enchanted object page. Could you please clarify ?
    Best regards,
    Frederick
  • doctorcdf
    0 doctorcdf over 11 years ago in reply to fvan
    My mistake: apparently there isn't an additional budget.  Apologies.
    But still no limitations, other than already stated, on additional materials?
  • doctorcdf
    0 doctorcdf over 11 years ago in reply to e14 Contributor
    Rick - no: the idea is you use the kit provided as the basis of the solution and then build upon it using whatever materials you deem fit.
    0 e14 Contributor over 11 years ago in reply to doctorcdf
    Thanks Christian,
    Not meaning to beat a dead horse, I just want to make sure I'm clear on the rules. image
  • cstanton
    0 cstanton over 11 years ago
    The limitations are whatever your project(s) require to your specification.
    So basically whatever you set for yourself. image
