Energy Harvesting Design Challenge
  • Energy Harvesting Design Challenge
Blog A Very Compact Guide to Energy Harvesting - Part 002
  • Author Author: COMPACT
  • Date Created: 11 Apr 2013 10:25 PM Date Created
  • Views 392 views
  • energy_harvesting_challenge
COMPACT
COMPACT
11 Apr 2013
Did you pick the odd one out?
There is no odd one out.
These are all energy harvesting sources that have been successfully used.
     The Car Fridge is Thermal Energy Generator Source
     The Electric Drill is an Inductive Energy Source
     The Electronic Cymbal is a PiezoElectric Source
     The Drum Synthesiser is a Current Loop Source
The wires coming out of the each device are tap points that I have attached to harness the energy without affecting the original function of the devices.
  • The fridge was used in reverse. I put in an ice block into the fridge. This created a temperature difference and thus thermal energy was generated and harvested.
  • The cordless drill was used in reverse and I used its electric motor and gearbox as a dynamo to generate inductive energy via it magnets and coils. A single crank on the chuck by hand is sufficient.
  • The cymbal was beaten hard and repetitively to generate piezoelectric energy that was harvested. The harder one hits the cymbal the more voltage and energy is produced.
  • Although not the odd one out it is an unusual choice. The Rhythm Sequencer(Drum Machine) has a MIDI interface (which is a current loop interface).
  • vsluiter
    vsluiter over 13 years ago
    Cool!
    Nice example of sources lying around the house. McGyver would have been proud of you!
  • vsluiter
    Cool!
