Energy Harvesting Design Challenge
  • Energy Harvesting Design Challenge
Blog A Very Compact Guide to Energy Harvesting - Part 005
  • Author Author: COMPACT
  • Date Created: 20 Apr 2013 7:32 AM Date Created
  • Views 787 views
  • energy_harvesting
  • energy_harvesting_challenge
COMPACT
COMPACT
20 Apr 2013
Delivered As Promised!
As a promise to Gerrit here is a silent video of the Energy Harvesting To Go Kit operating a LED using the onboard TEG (Peltier device).
  • I've disconnected the EFMGG_STK3700 from the Energy Harvesting board and replaced it with a white LED.
  • I've also selected the TEG power source using JP2.
Aside from that no other modifications are required.
The silent video shows my hand heating up the TEG to produce power to periodically blink a white LED.
The LED will blink 3 times from the energy harvested from my hand.
With a more capable TEG you could power a LED headlight with heat difference alone.
Notes: The yellow patch lead is only to reconnect the onboard TEG to its interface circuit. It was desoldered from the PCB to enable me to connect my car fridge.
I can now easily connect other TEGs.
  • gelmi
    gelmi over 13 years ago
    Try to add a resistor to this LED to regulate the current. I believe you can get the LED to light continuously and not only blink. The STK with the temperature program uses 2 mA. With the warm hand you can get even more power.
  • gelmi
  • COMPACT
    COMPACT over 13 years ago in reply to gelmi
    The flashing is deliberate to give the brightest output. I've had the LED on continuously on but it is considerably dimmer.
    As different as chalk and cheese.
