Documents Experimenting with Current Sense Amplifiers
  • Author Author: dychen
  • Date Created: 4 Feb 2022 9:03 PM Date Created
  • Last Updated Last Updated: 16 May 2022 6:39 PM
  • Views 13669 views
  • Likes 11 likes
  • Comments 37 comments
In this competition, participants will have an opportunity to experiment, test, or build a circuit with the MAX40080 by Maxim Integrated, a high-precision, fast-response, bi-directional digital current-sense amplifier.
profile image sensors
About Competition | Blogging | Example Application | Resources | The Dates | The Prizes | The Kit | The Judges | Terms & Conditions | The Challengers
The need is growing rapidly for fast and accurate current sensing for overcurrent (fault) protection, current metering, power monitoring, battery management and monitoring, as well as high-power converters. Current sensing is essential for products spanning industrial automation, telecom infrastructure equipment, portable appliances, and battery-operated devices. Current sense amplifiers (CSAs) are designed to perform this important function.
A current sense amplifier (also called a current shunt amplifier) is a purpose-built differential amplifier IC that is designed to sense the voltage developed across a current shunt resistor and output a voltage proportional to the measured current. Today's current sense amplifiers are high-precision, bi-directional devices with digital outputs, fast sampling rates, and very wide input common-mode range.
How To Enter This Competition
Before we talk about what the participants will receive in the Challenger’s kit as well as the great prizes they are competing for, let's talk about how to enter this competition, the timeline, and some FAQs.
How do you enter the Experimenting with Current Sense Amplifiers competition?
All you need to do is log into the Community, go to the Experimenting with Current Sense Amplifiers enrollment page, then click Enroll Now. The application entry form will appear. Complete the application form with all required information. Then click submit.
Who is Eligible to Enroll in the Experimenting with Current Sense Amplifiers Competition?
Any element14 member can enroll in the Experimenting with Current Sense Amplifiers competition; however, to receive one of 10 FREE kits, you need to submit an application entry form by the enrollment deadline, March 20, 2022.
What are the milestones of the competition?
Enrollment Begins: February 17, 2022
Enrollment Ends: March 20, 2022
Applicants Selected: March 25, 2022
Challenge Begins: April 8, 2022
First Blog Due: April 20, 2022
Second Blog Due: June 7, 2022
Challenge Ends: June 7, 2022
Winners Announced: June 2022
Blogging Requirements: Only 2 Blogs!
In order to successfully finish this competition, you are required to blog twice during the competition period. You can blog more than twice, if you wish. There are due dates for the blogs as described below:
  • Write Blog 1: Introduce yourself in the blog and explain what experiments you plan to perform. The due date for publishing the first blog on element14 is April 16, 2022.
  • Write Blog 2: Write up the results of your experiments, using images, screen captures, videos, tables, charts, etc. Then tell us what you learned about current sense amplifiers. The due date for publishing the second blog on element14 is May 31, 2022.
Please also tag your blogs with 'Experimenting with Current Sense Amplifiers'.
The Prizes
There will be two big prizes awarded in this competition: a Grand Prize and a Runner Up prize. We also offer a complimentary finisher prize to those who have met the requirements for finishing the competition, but have not been chosen for the Grand and Runner Prizes. (Note: The Grand and Runner Up Prize winners will not receive a finisher prize.)
The Grand Prize
Apple iPad Pro 12.9 + Apple Smart Watch
Apple iPad Pro 12.9 + Apple Smart Watch ($1298)
The Runner Up
Component Tester
Testing Tweezer LCR Meter ($398)
The Finisher Prize
Multicomp Pro Multimeter
Multicomp Pro Multimeter ($17.23ea)
Take A Closer Look at the MAX40080 Current Sense Amplifiers
Participants will receive a kit that contains the MAX40080 Current Sense Amplifiers, which is mounted on a MikroElektronika ClickBoard. Let's take a moment to learn more about it.
block diagram
Block Diagram of the MAX40080 Current-Sense Amplifier
See Datasheet
The MAX40080 is a high-precision, fast-response, bi-directional, current-sense amplifier with digital output and a very wide input common-mode range from -0.1V (ground sensing) to 36V. The device features an ultra-low 5µV input offset voltage and very-low 0.2% gain error. The low input offset voltage is especially important because it allows using a small sense resistor, thus saving power dissipation, but at the same time not compromising the measurement accuracy. It is also capable of measuring the input common-mode voltage up to 36V.
The MAX40080 includes an analog-to-digital converter with programmable sample rate and 12-bit resolution (13-bit including sign bit for current measurement) and features an I2C compliant and SMBus compatible interface. The MAX40080 features a wake-up current threshold and auto-shutdown mode when the I2C interface is inactive. Both features are designed to minimize power consumption. The MAX40080 is available in a small 12-pin WLP (and also a 12-pin TDFN) and is specified over the -40°C to +125°C extended operating temperature range.
Benefits and Features
  • Wide Input Common-Mode range from -0.1V (ground sensing) to 36V
  • Very low 5µV Input Offset Voltage allows using a small sense resistor
  • I2C compliant and SMBus compatible interface with smart modes to save power: (i) Wake-up current threshold, (ii) Low 4 measurements/s rate, and (iii) Auto-shutdown when I2C is inactive
  • Programmable Sample Rate up to 1Msps
  • Bi-directional current sensing
  • Common-Mode voltage monitoring up to 36V
  • Space-saving 12-bump WLP (0.4mm pitch) and 12-pin TDFN
  • Peak Current Log
  • Programmable over-current/voltage thresholds and under-voltage threshold
  • Alert output with programmable response time
  • 64-cell deep FIFO
The Kit
element14 is offering 10 kits FREE of charge. To be eligible to receive one of them, you must submit an application by the enrollment deadline (March 20, 2022). See kit below:
Product Description Buy Now
MIKROE-4914 Current 6 Click PIC: This add-on board features the MAX40080, a fast-response bi-directional current-sense amplifier. Buy Now
MIKROE-2756 Expansion Board, Pi 3 Click Shield For raspberry Pi, 2 x MikroBUS Connectors for Click Boards Buy Now
Raspberry Pi 3 Model B A Single Board Computer, Raspberry Pi 3 Model B, 1.2GHz CPU, 1GB RAM, WiFi/BLE, 40 GPIO Pins Buy Now
Anyone Can Participate in Experimenting with Current Sense Amplifiers Competition
Any element14 member can enroll in the 'Experimenting with Current Sense Amplifiers' competition. To receive one of the 10 FREE kits, you need to submit an application by the deadline, Mar 20, 2022.
Resources/Technical Documentation
Farnell/Newark
MAX40080ANC+
Maxim Integrated
MAX40080: Precision, Fast Sample-Rate, Digital Current-Sense Amplifier
MAX40080 Datasheet
Design Solution 7598 Industry's Fastest Sample-Rate Digital Current-Sense Amplifier
MikroElektronika
software: Current 6 click
Frequently Asked Questions (FAQs)
What kind of experiments can the participants perform with the current sense amplifiers?
How you experiment with them depends on your interests and what stirs your curiosity about current sense amplifiers. But CSAs can be used in power monitoring, overcurrent protection, diagnostic circuits, chargers, and portable/battery-operated devices, among others. They are also used in Industrial Control and Automation, Telecom Equipment, Base-Station PA Control, and Server Backplanes.
What do I need to do to win the Grand or Runner Up Prize?
After the enrollment period is completed, and the 10 FREE kits are shipped, you will have 8 weeks to complete your experiments, write the required two blogs, and share what you learned about Current Sense Amplifiers. You will be judged by the quality of your final blog and what you learned.
Can I still be eligible for the Grand Prize or Runner Up Prizes if I am not selected for one of the 10 kits?
Yes, on the condition that you obtain the MAX40080 current sense amplifier featured in the kit and perform experiments with it, and post your blogs in the Experimenting with Current Sense Amplifiers Group. You must write and post two blogs before the deadline. Also, please notify rscasny@newark.com with links to your two blogs.
What do I get if I don't win the Grand Prize, but I wrote the two blogs?
If you write two blogs and post them in the Experimenting with Current Sense Amplifiers Group by the deadline on May 31, 2022, you have successfully completed your entry in the competition. If our judges do not select you for the Grand or Runner-Up prizes, you will be eligible to receive the finisher prize, as a thank you for participating. But remember, you have to write two blogs by the deadline to be considered a finisher!
Tips on Writing Your Application
If you want to get a chance to receive one of the 10 FREE Kits, you will need to submit an application no later than March 20, 2022. The key to writing a winning application is to provide as much meaningful information about your proposed experiments as possible.
The application entry form should be detailed enough to give a good idea of what you plan to do and how you plan to pull it off. But you don’t have to write a book! By answering each of the following questions in your application, you will provide enough information:
(a) Describe your technical background.
(b) Why are you interested in this competition? What interests you about current sense amplifiers?
(c) What kind of experiment(s) do you plan to perform? (Be as specific as you can)
(d) Have you participated in the element14 Community? If so, please provide some links to what you've done. If you are a new member, answer "New Member."
All interested element14 members must submit an application entry form before the end of enrollment on March 20, 2022.
Here are some other suggestions for completing a winning application:
  1. Please complete all required information (contact information, etc.) Please use the email address that is associated with your element14 profile.
  1. Answer all of the application questions. Tell us why you want to be selected. Before deciding what you want to write, think about the following things:You are entering a competition. The most persuasive applications are the ones that attract the eye of the judges.
A single sentence application will never be selected. This competition is not a game of chance.
Be as detailed as possible, but don't write a book.
The Judges
Top Members of the element14 Community will be our judges. They are:
Top Member Don Bertke
Don spent 35 years in the aerospace industry working on many advanced projects. His range of experience covers nearly every scientific field and most ranges of the electromagnetic spectrum. He has a very broad interest and knowledge in science with extensive analysis in image, multispectral and hyper-spectral analysis. He has also worked on a wide range of embedded computer applications, including integrated search and rescue systems.
Top Member Doug Wong
Thank you to our Judges for offering their time and service.
General Questions
For any general questions about the ‘Experimenting with Current Sense Amplifiers’ competition, please post a comment on this page.
To keep up-to-date with this competition, please bookmark it.
Terms & Conditions
  • maxim integrated
  • experimenting with current sense amplifier
  • current sense amplifier
  • guillengap
    guillengap over 4 years ago +2
    I have achieved in this challenge my maximum number of views in a simple blog (13634 views on May 24) ... I suggest the organizer and sponsor of these challenges to reward these kind of achievements: Blog…
    dougw over 4 years ago +2
    guillengap The element14 staff, sponsors and members are doing a tremendous job of making this the best tech forum on the Internet, and they are always open to suggestions for improvement. If you can think…
  • aspork42
    aspork42 over 4 years ago +1
    OOOOOO --- I have a cool project that I want to do with this definitely submitting an application. Looks like this can support up to 5 amps the way they have it set up with the current shunt.
  • colporteur
    colporteur over 4 years ago
    I have a project I would like to use for this competition but I am not sure if the sensor would work. Please share your insight.
    I would like to detect the model train on a section of track. In model railroading, it is called Block Detection. The locomotive motor draws current. Blocks of tracks are isolated from each other and there are mechanisms to detect the current in a block.
    I've wanted to look at a more economical approach than what I have seen so far. Maybe this sensor is the key? I looked at the schematic for the sensor and can't see how I would insert the unit into the above circuit to detect the locomotive.
    I don't want to enter the competition without chance of success. It's not about winning the competition. It is more about receiving hardware without being able to deliver on a goal. Right now I can't see how I would make it work.
    I looking for some suggestions that I could explore. Maybe there is someone willing to share their insight to see if there is a way to use the sensor for this circuit.
  • colporteur
  • aspork42
    aspork42 over 4 years ago in reply to colporteur
    Are you saying that each segment of track is individually powered; and they transfer power to the train engine? If so; then you should be able to do what you're thinking. Just put this in-line with the segment of track you'd like to monitor. It should be zero current up until the train enters that segment, then jump to an amp (or whatever the train draws). Note that this kit is only one current sensor; so you would only be able to monitor one segment of track.
  • colporteur
    colporteur over 4 years ago in reply to aspork42
    You are correct. Power block detection requires each block of the track to be separated and monitored. Block detection can be done by detecting the magnetic field of the locomotive or its physical presence by breaking an IR beam. The issue becomes the cost of individual sensors. A standard track length is 3ft. If each track section is a block, the math of block detection cost is easy to find. This sensor is cheaper than the ones I have seen designed in the industry.
    Looking at the schematic, for what I assume is the input for the sensor, I'm confused about how I would physically connect the sensor. If RS are the inputs I don't have a sense resistor. I don't think I have the connection defined correctly.
  • misaz
    misaz over 4 years ago in reply to colporteur
    I am not sure if it would work with idle (stopped) train. But maybe someone will correct me. Otherwise idea looks correct to me. Does your train consume any current when it is stopped? How do you control train? Do you control train by voltage in rail or you have some kind of smart train controlled by onboard MCU and rail is powered by constant voltage? In case of standard train controlled by chaning voltage in trail you should be able detect moving train, you should be able to detect direction of moving of train and even more, you could estimate speed of train using this sensor. The only issue in this case is with detection of stopeed train (stopped train can also occupie block and you should detect them to correct operation). This is problem because when voltage is set to 0V, you efficently cannot determine if there are or threre are not any train. You can resolve this issue for eaxample by addind parallel resistor (value of resistore requires further computations and tweeking) making minimal power detectable consumption and prevent setting rail to 0V but for example set it to some low non-zero voltage when you want to stop train (this voltage also require futher calculations and tweeking). Other possible (software only!) solution would be implementing something that in Czechia we refer as "full block condition" which means that block is released if and only if train free the block and also occupy following block (the second part is very important). This means that for exmaple derailing will not release block because although train leaved block, it did not occupied fopllowing block. You can implement it and when you detect that voltage is 0V and train did not occupied next block, you can determine that block is occupied by stopped train rather than block was freed.
  • colporteur
    colporteur over 4 years ago in reply to misaz
    Two types of control for trains. Direct Control (DC) and Digital Command Control (DCC). The DC system varies the voltage to control the locomotive speed. The DCC has a decoder in the locomotive that communicates back to a controller using the rails as a network path. In the DCC system, the voltage on the rails is fixed. The decoder manages the locomotive speed.
    My premise is the current drawn by a locomotive can be detected by this sensor. I suspect it can but my initial confusion is how.
    The conditions you described, the locomotive stopped, the locomotive with variable speed were issues I would explore through the project if the detector worked. Also, look at the sensor in a DC versus a DCC environment. Does the sensor impact DCC communication? I had a few other areas to explore also.
    I'm stuck on how to install the sensor on a layout and have the confidence it will actually get a reading. I hate to be awarded a kit and have to say the sensor can't be installed to detect a locomotive.
  • misaz
    I think the connection shold looks as follows:
    of couse make physical connection, track circuit modifications and so on can be also very hard.
    Sensor do not affect anything, at least theoreticaly. Sensor connects to circuit using "anolog input pins" (efficiently Hi-Z). Only thing that affect circuit is shut resistor which has very small value so it does not affect circuit significantly, but affect it little bit. So, sensor definitely will not affect DCC. But I little worry about question from reverse side: Does DCC communication impact sensor? And this require further analysis, but I think it does. I have no DCC available currently but according to https://en.wikipedia.org/wiki/Digital_Command_Control I think at least toglling polarity done by DCC can cause measurements analysis more tricky and will require some work and further investigations.
    I recommend trying it. Contest is named "Eperimenting with ... ". Even failed experiments are experiments and this experiment would be very cool. Also note in case when you find some unresolvable troubles when implementing it you can still fall back to some standard test and experiments.
  • colporteur
    Really appreciate you sharing your insight. Awesome block diagram. The sensor would be no different than other current detections methods I have examined. The block diagram threw me for a loop.
    I confess I am not a model train guy. I don't enjoy the running trains part of the hobby. My career(s) background is in electronic technology. I associate with model train guys. My background is valuable in their hobby. I typically implement scenery animation using light, sound and motion on a friend's layout using microcontrollers and single-board computers.
    I do enjoy exploring different areas associated with the hobby.  I find the component stuff for the hobby expensive. I'm always looking for ways to reduce costs. Most of the members I hang with, don't have the knowledge to explain how things work. I have to discover that by reading and experimenting.
    I don't think voltage polarity is reversed on the rails in the DCC system. I make this assumption because you can run a number of locomotives with decoders on the same line, with some going forward some going backwards, all at the same time. I think the reversal is done in the decoder but again I am guessing.
    This kit includes a Pi. Now that suggests the sensor and the Pi have some symbiotic relationship. I have experience with Pi's and interfacing them to the outside world. More than one sensor would be ideal. I may have to purchase one if awarded a kit so I can fully explore implementation options. I have a host of questions the competition raises. It all starts with answering the question can I get a reading?
    I like your fallback approach. If all else fails I will deliver this suggestion. Thanks for the encouragement.
    dougw over 4 years ago in reply to colporteur
    As other have suggested, it looks like it will detect the current by connecting it in series with any block to be monitored. Presumably the current reading is proportional to speed but also depending on the load, so you could use it to make a speedometer. It measures both polarities, so it will also measure the train reversing.
    The sensor is just a 35 milliohm resistor that you connect with the screw terminals - in series with your track block power. This small resistance shouldn't have any noticeable effect on train performance. The V+ and GND terminals are to supply power to the sensor circuit. If the train power supply voltage exceeds the Click module supply voltage, I would put the sense resistance in series with the train ground. However you need to figure out what happens to the train voltage when the train reverses - relative to your Click power supply. If all blocks have the same ground, you would only need this one sensor to monitor the whole track. In that case it wouldn't tell you which block had the train.
