Experimenting with Industrial Automation
  • Experimenting with Industrial Automation
Blog A Box Full of Industrial Automation - 4
Join Experimenting with Industrial Automation to participate - click to join for free!
  • Author Author: kmikemoo
  • Date Created: 26 Feb 2024 4:16 AM Date Created
  • Views 1035 views
  • Likes 9 likes
  • experimenting with industrial automation
  • design challenge
  • schneider electric
kmikemoo
kmikemoo
26 Feb 2024
Training Bay Ventilation Automation
I actually did the video for this unboxing a few weeks back but my concern for being able to complete the design challenge in time caused me to shift to the project more than the blogs.  Sorry.  The project is going well so back to sharing the adventure.
So... what's in the box?
image     image
DISCLAIMER:  I thought I would be able to grab better still pictures from the video than I can.  Instead of showing you fuzzy screen grabs, I will be using some of Schneider Electric's pictures.  I'll include the one of the PLC just so you know what you're not missing.
Each component title is also a link to more information on the product.
TM251MESE PLC
image     image
HMIST6200 HMI
image     image
ABLM1A24025 Power Supply 24VDC 2.5A
ZBRA1 Relay Antenna
ZBRN2 Harmony Hub (Wireless Serial Gateway)
ZBRA2 External Antenna
ZBRRH Wireless Receiver
While the remaining components are small  in size, they are BIG in in the benefits of the Harmony ecostructure.  You need good input to get meaningful output.  Right?
1 - ZB5AK1233 Wireless Selector Switch
2 - ZB5AW333 Push button
3 - ZB5AZ009 Collar
4 - 70-782D8-1A Relay Socket
782XBXM4L-24D Power Relay
ZBRT2 Transmitter
Not In The Box
If you were able to watch the video, you would know that I purchased an additional three relays with bases - should I want to use them with the ZBRRH receiver module.  And... my project requires wired inputs and outputs - so I purchased the IO Expansion module below.
TM3DM8R Discrete IO Module
This IO module has four digital inputs and four relay outputs capable of handling 2A each.
Summary
These are components that came "in the box" and a few that I added to make a functional project.  Again, thank you Schneider Electric and element14 for providing so many cool components for this design challenge.
2024-02-28 Late Addition
The postman dropped off one more component - compliments of Schneider Electric and element14...
ZBRV1 Visual Feedback
image     image
This is a pretty cool indicator.  It flashes briefly to confirm that the switch transmitter's "message" was sent and received by the Harmony communication hub.
  • kmikemoo
    kmikemoo over 2 years ago
    2024-02-28  Surprise addition to "The Box".  I received the ZBRV1 Indicator today.  It's supposed to indicate 50,000 transitions.  It's a nice indication that your wireless switch transmitter actually worked. ThumbsupThumbsup
    DAB over 2 years ago
    You have a lot of interesting components.
    I look forward to seeing what you build with them.
    genebren over 2 years ago
    Interesting array of component for your project!  I look forward to seeing this all come together as your project continues.
