Experimenting with Thermal Switches
  • Experimenting with Thermal Switches
Challenge Blog Blog 2:- The Thermal Switches Experimenter’s Kit
  • Challenge Blog
  • RoadTests
  • Author Author: manojroy123
  • Date Created: 18 Mar 2022 12:15 PM Date Created
  • Views 765 views
  • design challenge
manojroy123
manojroy123
18 Mar 2022
The Thermal Switches Experimenter’s Kit:-
The kit consist of thermal reed switch and thermal guard switch as shown in the figure 1 bellow
Figure 1
 Some question that needs to be answered
What are thermal reed switch ?
Thermal Reed Switch is a highly reliable, precise temperature-sensitive switch. Its unique proprietary design features a magnet and a temperature-sensing soft ferromagnetic substance called Thermorite®. The material’s magnetic flux density decreases as the temperature increases turning it into a paramagnetic substance at the Curie temperature.
What is  Thermorite ?
Thermorite is ferri-magnetic material that changes its magnetic property rapidly at its Curie temperature.
What is a reed switch ?
The reed switch is an electrical switch operated by an applied magnetic field.
Working of reed switch ?
The switching mechanism is comprised of two ferromagnetic blades, separated by only a few microns. When a magnet approaches these blades, the two blades pull toward one another. Once touching, the blades close the normally open (NO) contacts, allowing electricity to flow.
Figure 2
Working of thermal reed switch ?
Thermal reed switch are either switch on or off depending upon the temperature and the type of thermal switch. In blog 3 you will see experiment with various thermal reed switches.
What are thermal guard switch ?
Thermal Guard (OHD) are temperature-sensing switches composed of a magnet and a temperature-sensing soft ferromagnetic substance called Thermorite. This material’s saturation magnetic flux density decreases as the temperature increases, and it turns into a paramagnetic substance at its Curie temperature
Anything more looking in the kit ?
Temperature indicating paint/paper also known as thermochromic piant/paper
