Experimenting with Thermal Switches
  • Experimenting with Thermal Switches
Challenge Blog Blog #4 Thermal simulations of the setup
  • Challenge Blog
  • RoadTests
  • Author Author: manojroy123
  • Date Created: 19 Mar 2022 2:56 PM Date Created
  • Views 915 views
  • thermal switch
  • experimenting with Thermal Switches
manojroy123
manojroy123
19 Mar 2022
In Setup 1 the liquid is not agitated because of which the temperature of the entire liquid is not raised to appropriate temperature. Only the temperature around the hot rod is raised rest of the area temperature remains the same. Which can be seen in the figure 1
Figure 1
 In Setup 2 the liquid is agitated because of which the temperature of the entire liquid is raised to appropriate temperature. Not only the temperature around the hot rod is raised but also the temperature of the remaining liquid is increased. Which can be seen in the figure 2
Figure 2
    DAB over 4 years ago
    Nice demonstration on the difference between convection cooling and active cooling.
