Experimenting with Vibration Sensors
  • Experimenting with Vibration Sensors
Blog Experimenting with Vibration Sensors - Machine Safety Blog #6
  • Author Author: dwinhold
  • Date Created: 15 Dec 2020 12:58 AM Date Created
  • Views 594 views
  • experimenting_with_vibration_sensors
  • dwinhold
  • kemet vibration sensor
dwinhold
dwinhold
15 Dec 2020
Machine safety Blog #6
I am doing this update because I went out of my comfort zone with programming. Years ago this wouldn't have been such a big deal for myself and I'm sure lots of you reading this could do it in your sleep. For me, I'm kind of proud of what I did.
So my issue was I wanted to test the sensor on other things besides machinery. Just a simple program to read the sensor. So I was loading the Arduino with the simple code then reloading it with the machinery safety code. Back and forth over and over. To solve this I had 2 options, run 2 Arduino's or create a program that gives you a choice on which program you want to run. I did the 2nd choice.
Below is the program that allows you to have a choice of which program you want to run:
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int vib = A0; //Vibration sensor pin
int safelt1 = 8; //Assign warning LED
int safelt2 = 9; //Assign warning LED
int warnlt1 = 10; //Assign warning LED
int warnlt2 = 13; //Assign warning LED
int shutdwnlt = 14; //Assign warning LED
int shutdwnsw = 7; //Assign shutdown switch
int data; //Sensor reading
int average = 0; //Average reading
int averageA = 0;
int averageB = 0;
int x = 0; //Loop count
int y = 0; //Creates infinate loop
int tread = 0; //Temporary read
int hread = 0; //Highest reading
const byte modeButton1 = 18;
const byte modeButton2 = 19;
void setup(){
  pinMode(modeButton1, OUTPUT);
  pinMode(modeButton2, OUTPUT);
  pinMode(shutdwnsw, OUTPUT);
  digitalWrite(shutdwnsw, LOW);
  digitalWrite(modeButton1, LOW);
  digitalWrite(modeButton2, LOW);
  lcd.clear();
  lcd.begin(16, 2);
  lcd.setCursor(3,0);
  lcd.print("Vibration");
  lcd.setCursor(5,1);
  lcd.print("Sensor");
  delay(3000);
  pinMode(vib, INPUT); //initialize vib sensor as INPUT
  Serial.begin(9600); //begin the serial monitor at 9600 baud
  lcd.clear();
void loop(){
  lcd.setCursor(0,0);
  lcd.print("A-Run Program");
  lcd.setCursor(0,1);
  lcd.print("B-Run Test");
  // if button A pressed
  if(digitalRead(modeButton1) == HIGH)
    programOne();
  // if button B pressed
  if(digitalRead(modeButton2) == HIGH)
    testTwo();
//Run the vibration program
void programOne()
  lcd.clear();
    do{ //Calibrate average vibration
      x = x + 1;
      averageA = analogRead(vib);
      averageB = averageB + averageA;
      Serial.println("Calibrating");
      lcd.setCursor(0,0);
      lcd.print("Calibrating");
      lcd.setCursor(0,1);
      lcd.print("XXXXXXXXXXXXXXX " + x);
      delay(500);
      } while (x < 15);
      average = averageB/15;
  do{
    delay(100);
    data=analogRead(vib);
    Serial.println(data);
    digitalWrite(safelt1, HIGH);
    tread = data;
     // Set highest reading
     if(hread < tread) {
      hread = tread;
    if(data <= (average*1.05)){
      lcd.clear();
      digitalWrite(safelt2, LOW);
      digitalWrite(warnlt1, LOW);
      digitalWrite(warnlt2, LOW);
      digitalWrite(shutdwnlt, LOW);
      Serial.println("Within Limits");
      lcd.setCursor(0,0);
      lcd.print("Ave="); // Average
      lcd.setCursor(4,0);
      lcd.print(average);
      lcd.setCursor(10,1);
      lcd.print("HR="); //Highest recorded
      lcd.setCursor(13,1);
      lcd.print(hread);
      lcd.setCursor(0,1);
      lcd.print("--------");
      lcd.setCursor(10,0);
      lcd.print("CR="); //Current recorded
      lcd.setCursor(13,0);
      lcd.print(data);
    else if(data <= (average*1.1)){
      lcd.clear();
      Serial.println("Within Limits High");
      lcd.setCursor(0,0);
      lcd.print("Ave=");
      lcd.setCursor(4,0);
      lcd.print(average);
      lcd.print("HR=");
      lcd.print(hread);
      lcd.setCursor(0,1);
      lcd.print("XX------");
      lcd.print("CR=");
      lcd.print(data);
      digitalWrite(safelt2, HIGH);
    else if(data <= (average*1.2)){
      lcd.clear();
      Serial.println("Warning Limits");
      lcd.setCursor(0,0);
      lcd.print("Ave=");
      lcd.setCursor(4,0);
      lcd.print(average);
      lcd.print("HR=");
      lcd.print(hread);
      lcd.setCursor(0,1);
      lcd.print("XXXX----");
      lcd.print("CR=");
      lcd.print(data);
      digitalWrite(warnlt1, HIGH);
    else if(data <= (average*1.35)){
      lcd.clear();
      Serial.println("Warning Limits High");
      lcd.setCursor(0,0);
      lcd.print("Ave=");
      lcd.setCursor(4,0);
      lcd.print(average);
      lcd.print("HR=");
      lcd.print(hread);
      lcd.setCursor(0,1);
      lcd.print("XXXXXX--");
      lcd.print("CR=");
      lcd.print(data);
      digitalWrite(warnlt2, HIGH);
    else if(data <= (average*1.5)){
      lcd.clear();
      Serial.println("Shut Down Required");
      lcd.setCursor(0,0);
      lcd.print("Ave=");
      lcd.setCursor(4,0);
      lcd.print(average);
      lcd.print("HR=");
      lcd.print(hread);
      lcd.setCursor(0,1);
      lcd.print("XXXXXXXX");
      lcd.print("CR=");
      lcd.print(data);
      digitalWrite(shutdwnlt, HIGH);
  else if(data > (average*1.5)){
      Serial.println("Shutting Down");
      lcd.clear();
      digitalWrite(shutdwnsw, HIGH);
      lcd.setCursor(1,0);
      lcd.print("Limit Exceeded");
      lcd.setCursor(8,1);
      lcd.print("Max=");
      lcd.setCursor(12,1);
      lcd.print(data);
      delay(5000);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Press Button to");
      lcd.setCursor(2,1);
      lcd.print("Reset Sensor");
        while(0 == 0); // Causes infinate loop
   delay(100);
}while (y == 0);
//Test the vibration sensor
void testTwo() {
      x = x + 1;
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      delay(500);
      } while (x < 15);
  do{
    delay(100);
    tread = data;
     if(hread < tread) {
      hread = tread;
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Ca=");
      lcd.setCursor(3,0);
      lcd.print(average); //Display average vibration
      lcd.setCursor(8,0);
      lcd.print("CR=");
      lcd.setCursor(11,0);
      lcd.print(data); //Displays current vibrations
      lcd.setCursor(8,1);
      lcd.print("HR=");
      lcd.setCursor(11,1);
      lcd.print(hread); //Displays highest vibration reading
      delay(100);
  }while (y == 0);
Like I said, it may not be anything new, but it was for me and it works!!
Dale Winhold
