Experimenting with Waterproof Connectors
  • Experimenting with Waterproof Connectors
Blog Sensors Integration - Blog 3
Join Experimenting with Waterproof Connectors to participate - click to join for free!
  • Author Author: charlieo21
  • Date Created: 31 May 2023 4:57 AM Date Created
  • Views 514 views
  • experimenting with Waterproof Connectors
charlieo21
charlieo21
31 May 2023
For this weather station I added the following sensors.
Humidity & Temperature (Inside the enclosure and external)
I'm using the HS3001 from Renesas. I put one inside the enclosure and other one outside the enclosure.
UV Sensor
I'm using the VEML6070 from Vishay.
I need to fine a good way to protect this sensor from the weather but also allow the UV measurement.
Air quality
I'm using the ZMOD4510 from Renesas.
I created a small weather shield to protect the air quality and humidity & temperature sensors.
I used cheap plastic bowls to build the weather shield. This will protect the sensors from solar radiation, wind and rain
