Design Challenges
Design Challenges
Forum 25-45 DC in, I need 12V DC out.
  • Replies 32 replies
  • Answers 18 answers
  • Subscribers 11 subscribers
  • Views 6001 views
maroka
maroka over 9 years ago
I need stable 12v for the LED turn signals on my motorcycle but the bike doesn't have a battery (from the factory) so everything is in AC. I used a bridge rectifier (KBPC5010) which outputs anywhere between 25-45 volts DC (maybe even more since I didn't rev it too high and it depends on engine RPM) but my flasher relay works on 12V. I made a circuit containing a 1000uF capacitor, 7812 stabilizer and 2 smaller ceramic capacitors, the components were connected in that order. It worked, the output I got was a stable 11.9V (according to my butchered multimeter). I put all of that in a plastic shroud from a glowplug relay and hot glued everything in place. It worked for a little bit until it stopped working, the capacitors are fine but the 7812 stabilizer shows no voltage on the output pin. My question is, did I fry it with too much voltage coming out of the rectifier, or was my mistake inadequate cooling? What would you guys suggest I build to make my turn signals work? Thanks in advance!
  • maroka
    0 maroka over 9 years ago in reply to WarrenW
    Allright, just got done testing the zener with the transformer I got, it was reading around 13V across it while radiating a considerable amount of heat. I think I baked it back at the lab because there was some smoke coming out when my teacher tested the zener, I guess the PSU there supplied too many amps. Flipping it around gave me around 0.03V while attached to my transformer but it was buzzing a lot louder. Warren, just to confirm, you're suggesting I build a new circuit with the values you stated above? I once again apologize for my newbie questions, it's all a little complicated to me.
  • WarrenW
    0 WarrenW over 9 years ago in reply to maroka
    What you want to do is make sure that the zener is regulating - as suggested remove the transistor. Your 18V transformer with a bridge should be fine for confirming the zener is indeed regulating. This simple circuit is effectively known as an emitter follower series regulator. The base of the transistor is held at the zener voltage and the output (emitter) will be approx. 0.6 volts lower than the zener voltage (with a small load on it - less than 0.5 amp). The regulation will be pretty stable as the current into the load increases. If you are using a BDX33 this is a darlington arrangement (effectively 2 transistors in one package), it requires less drive current into the base as you have 2 transistors to 'amplify' the current. With 2 transistors you have 3 base emitter junctions each at 0.6v so the output voltage will be 1.2volts lower than the zener voltage, but would be VERY stable under even small loads.
    Assuming the Hfe (current gain) is 100 and you want 1 amp of output. 1 amp divided by the gain would be the required input current to the base. Or in this case 10mA. For good regulation the zener current should be approx. 5 times the base current so let us assume we will want a total of 60mA (10 to the transistor and 50 to the zener). The zener voltage is 12 volts and when running at 50mA (P=I*V) the power dissipated would be 600mW so a 1 Watt zener is the smallest you would go for.
    The real problem you have is the very wide range of input voltage. If we say you have 45 volts of input, the voltage dropped across the resistor is going to be 45 -12 = 33 volts. We have to supply the zener / transistor with 60mA so that makes the resistor value 33/.06 = 550 ohms (closet is 560) and the wattage will be 33*.06 or 2 watts.
    As the input voltage decreases the amount of voltage across the resistor drops and therefore the current into the zener /transistor drops as well. At 24 Volts input we have only 12 volts across a 560 ohm resistor = 20mA  if your load is 1 amp and the transistor is 100 gain then you have 10mA going into the base and 10mA into the zener. It will still regulate but is now dependant upon the characteristics of the zener.
    Best option is to find a higher gain transistor as this will allow you to drop the current through the zener / transistor combination. A TIP142 may be a better option with a VCE of 50V allowing you input voltage to get close to 60V. It also has a current gain of 1000. This means for a 1A load you only need to supply 1mA into the base! you can run with 5 -10mA zener current and this means your zener can go down to a 400mW version if needed for better regulation. The resistor value would now be 3300 ohms to give you a 10mA current flow into the zener /transistor at the 45V input voltage.
    When the input voltage drops to 24V the current in the zener / transistor would then be approx. 4mA. All good!
    The resistor wattage also reduces to a 1/2 watt version.
    Hopefully this long drawn out response will be of some assistance.
    Warren.
  • maroka
    0 maroka over 9 years ago in reply to michaelkellett
    So if I opt for a different zener, the values are going to be closer to 12V correct? If so, I'm going to go to the hardware store and ask them for the specific part you specified. If it's not available, I should look for a replacement one with low current spec, correct? Thanks for the advice, everything becomes more and more clear with every reply I get!
    0 michaelkellett over 9 years ago in reply to maroka
    Its a pretty poor zener specced for a test current of 50mA. With 12V and 2k resistor your current would have been about 2.5mA and with the 30V in about 10mA. The spec of the zener doesn't say what it will do at such low (compared with the spec) currents but 8.6V is not impossible.
    The zener I suggested is better (test current 19mA) but it will still vary as the supply voltage varies.
    To get good results you need to keep the current in the zener closer to the test current but this is very difficult without using more parts.
    To check the zener you need a range of resistors or a variable power supply. Your home supply needs a capacitor across the output (1000 uF would do) if you are going to use it. So long as you measure the current and voltage through the zener for different resistor values you can still work out the characteristics of the zener.
    (It's just a bit easier if you have all the gear.)
  • maroka
    I've got a "Pro's Kit MT-1210" multimeter, it beeps and it's also got a back light. I think it'll get the job done. Thanks for the help, have a nice evening.
    I have to go home now but I'll make some suggestions first thing tomorrow.
    Have you got a reasonable voltmeter   ?
  • maroka
    Thank you for the suggestion! Thing is, that I don't have an adjustable DC power supply at home and the teacher doesn't have access to the lab at all times, so I'm not sure how to test it out. I've got a 1A 18V transformer with a bridge rectifier on it that my dad built long before I was born, but I'm not sure whether it will work for testing. I tested the little fan I was talking about (12V, 0.06A) and it caused the voltage from the transformer to drop to 15V, so I'm really not sure how to test it. The zener is "PL12Z" and a quick google search revealed that it is indeed a 12V zener (at least from what I managed to gather). About the capacitors, I'm pretty sure they're the right way around because we ran it for quite a while so my guess is that if they were flipped, they would've popped. Regardless I'll make sure to check them when testing. I apologize if I'm being a pain in the bottom, I feel too uneducated to be in this community, but I'm willing to learn. Once again, thanks to everyone for helping.
    Try removing the transistor and measuring the voltage across the zener for input = 10V ..... 30V in 5V steps.
    Check your caps are all the right way round.
    Check it is a 12V zener !
  • maroka
    0 maroka over 9 years ago in reply to maroka
    So today we tested the circuit on a project board and on the output we got about 7V with 12V in, so we put more voltage on the input and at 30V in (the maximum on the DC power supply we had on hand) we got 8.6V output. We put a 2K load resistor and the values remained the same. We measured the voltage across the Zener and it's the same as the output. Before I try to build the other scheme I'd like to know what went wrong so I know in the future. Thanks for the replies!
    0 michaelkellett over 9 years ago in reply to WarrenW
    It's a good suggested circuit for Vladimir's application - simple to build and cheap - just needed a little tweak (although he'll be OK if his LED lights draw only 100mA rather than the 1A that I guessed)..
    The trouble with using  a nice efficient switcher is that you either buy one of the dodgy Ebay made up boards or put a lot of effort into building your own.
    I've been having trouble with the gain of 2N3055s and their clones for 40 years - they were used in audio amps quite a bit in the 1970s  - the Quad 303 power amp used them. But the low gain (very low at high currents) and low Vceomax were always problems.
    I was amazed at just how cheap the BDX33C was  - got me thinking about designing an audio power amp using them !!
