Design Challenges
Design Challenges
Forum Will 24v dc 0.5 amp digital output operate a 24v dc relay 10m away using 0.8mm cable or will votage drop inhibit operation?
  • Blogs
  • Answers 2 answers
  • Subscribers 6 subscribers
  • Views 911 views
  • frontpage
ricard053
ricard053 over 9 years ago
  • johnfire
    0 johnfire over 9 years ago
    you may find this useful......
    Wire Gauges - Current Ratings
    0 jw0752 over 9 years ago
    Hi Ricardo,
    This will depend entirely on the resistance of the relay coil. Chances are it will be fine if the relay is designed to operate on less than the 0.5 amp current of your source. Most relays that are rated at a particular voltage will function just fine on 3/4 of that voltage. You might for the fun of it put a mA meter on the relay and see exactly how much it draws at 24 volts. Post back what you find as I am interested in your results.
