Design Challenges
Design Challenges
Forum Anyone know how to acquire audio signals from digital mics on a BB or BBB?
  • Blogs
  • Subscribers 6 subscribers
  • Views 608 views
  • design-challenge
I'm building a beamforming application requiring 8 mic input streams.  Any help would be much appreciated.
    0 shabaz over 11 years ago in reply to e14 Contributor
    Hi Vlad,
    I've added you as a contact, if it is anything useful to others then better to share it here, otherwise feel free to reach out with a private message.
    0 e14 Contributor over 11 years ago in reply to shabaz
    Hi Shabaz:
    Thanks a lot for your feedback.  How can I get in touch with you directly?
    Vlad
    Hi Vlad,
    The BBB has four digital streams marked AXR0..3, see here: http://www.element14.com/servlet/JiveServlet/downloadImage/105-30089-191306/mcasp-subsystem.png
    To make use of them would require ADCs and Linux driver experience. I don't know if any drivers exist that could make use of 8 channels today, so you may need to research that or develop/modify existing drivers.
    You could use stereo per channel (to allow making use of typical audio ADCs and have less to modify for existing drivers), or in fact any number of streams
    (hundreds are supported) in a TDM format (e.g. lots of A- or u-law) which is a bit more specialist. Basically it is _extremely_ flexible - one of the best boards for audio applications.
    EDIT: sorry, looks like I can't link to the image directly. You can see it here BBB - Building a DAC  search for the text 'AXR' and there is a diagram there - the one with blue and green shaded blocks.
