Design Challenges
Design Challenges
Forum Help with a school project
  • Blogs
  • Replies 11 replies
  • Subscribers 11 subscribers
  • Views 1750 views
  • frontpage
Hi all, my technology class has just received out state exam brief for our end of year project.
The main points of the brief are:
1. must be an item used by refugees or aid organisation in the event of a disaster.
2. must be electro-mechanical
Some of the ideas floating around the class are model rescue vehicles, wind-up torches. My idea, so far, is to make an emergency radio kit of some sort.
I was hoping the element14 community could pitch in ideas for me or just help me with my radio idea because from what iv seen here, you people are a lot smarter than I am.
Our classroom has all the tools and equipment you'd expect, laser cutter, lathe so keep that in mind.
Thanks in advance -Liam.
  • amgalbu
    0 amgalbu over 11 years ago in reply to dougw
    I think that's a great idea and matches all the requirements of your project
    0 dougw over 11 years ago
    How about a solar powered water still to generate clean drinking water?
    There is always room for a new design that uses readily available materials.
    You could add a solar UV light source for extra sterilization.
    260 nm LEDs may be a bit expensive, but there are other sources - even the sun - if you concentrate enough sunlight it might do the job.
    Well, if the prosthetic leg mirrored the other leg, wouldn't that make walking impossible? also I don't have even half the skill to pull off a prosthetic of any kind. Thanks though
    I dont know how good you are with robotics, but what if you made a prosthetic leg that mirrors bend/flex sensors on the other leg
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    That's probably more complicated than id like, as long as the project satisfies the brief I should be okay. It doesn't have to be as fancy as that, thanks for the suggestion though.
    in regards to the radio, I decided to order a radio circuit kit that, once assembled, is a functioning radio. I would need to laser cut a housing for it though. To satisfy the electromechanical part of the brief I was thinking of making a case to house both the radio and transmitter but im not sure how to incorporate any electromechanics into it.
  • gadget.iom
    0 gadget.iom over 11 years ago
    How about a rugged robotic device that can enter confined spaces, such as collapsed buildings and provide a video feed to the operator, perhaps even two way audio to the trapped person for reassurance that they have been found etc.
    The device could be radio controlled.
  • clem57
    0 clem57 over 11 years ago
    Liam,
        " must be an item used by refugees or aid organisation in the event of a disaster" First read this @Natural disaster refugees soar to 42 million - World news - World environment | NBC News and decide how a radio could be used... Good luck with the project
    That's one of the problems, a radio isn't really electromechanical, unless I turn it into a wind up radio. Technically the on/off switch is electromechanical but that might be stretching it.
  • gihu
    0 gihu over 11 years ago
    I think a radio using Citizens band, Citizens band radio - Wikipedia, the free encyclopedia, would be nice, but oem products use comercial frequencies image
    Just to fulfil the electro-mechanical budget, maybe a dynamo to supply the radio.
  • gadget.iom
    Will a radio system satisfy the electro-mechanical aspect of the project?
