Design Challenges
Design Challenges
Forum POLL-DISCUSSION - How Familiar Are You in Modifying An Electrical Enclosure?
  • Blogs
  • Replies 7 replies
  • Subscribers 13 subscribers
  • Views 2333 views
  • modifying an enclosure
rscasny
rscasny over 3 years ago
Electrical/Electronics enclosures often are modified for a particular installation. Sometimes, the engineer will do the modification, yet other times he/she will request a third party service provider or an enclosure manufacturer to perform the modifications.
Here is a typical list of enclosure modifications:
  • Holes
  • Cutouts
  • knock outs
  • Tapping and Countersinking
  • Pressed-in hardware (studs, standoffs)
  • Silk Screening
  • UV Printing
  • Special colors
  • Special length extrusions
  • Pre-Installed Accessories
  • Special Paint Colors
  • Non-Standard Sizes
  • Louvers
  • Alternate Handles
  • Add, Move or Delete Studs
  • Hinge Changes
  • Mounting Struts
  • Dimension Changes
  • Stiffeners
  • Windows
  • Shelves
  • Climate Control
POLL Question
  • robogary
    robogary over 3 years ago
    I do as much as I can while building alpha version panels and/or test panels.  Production or mod shop work , the techs prefer to help me , and I like it that way - they have more practice and do a better job than I do.
  • colporteur
    colporteur over 3 years ago
    I moved away from an aviation installation career in 1996. Bare metal rack to customized installed racks, complete with equipment was the groups role.
    michaelkellett over 3 years ago
    I've modified lots of boxes by simple machining of holes.
    I've been involved inn designing custom enclosures ( a long time ago).
    I've never used the services of one of the box manufacturers offering extensive customisation.
  • Andrew J
    Andrew J over 3 years ago
    Cut outs of various sizes: using drills, stepper bits for larger holes and coping/jewellery saws for even larger openings, eg LCDs, or square openings.  It’s easier to actually buy enclosures with end panels, design the layout required with cutouts and get a PCB manufacturer to create them out of 1.6mm aluminium.  The hardest thing actually seems to be sourcing a suitable enclosure in the first place: searching using site filters is frustrating.
    To be fair, I have/had no job that required any interacting with enclosures so I’ve been limited to home projects.
    dougw over 3 years ago
    I've specified and built lots of electronics enclosures - all aspects. I've never actually studied the electrical "code" so I don't work on high voltage electrical boxes, but I had a summer job as an electrician's helper way back, and I've picked up more of it along the way.
  • mp2100
    mp2100 over 3 years ago
    This is not something I do often, the experts at work would tell me “stay in your lane, bro”, but sometimes you’re at a remote site and fixes have to be done.
    DAB over 3 years ago
    Back in my early days, we had to do this type of modification all of the time.
    I would pick up a metal box and then drill and punch the appropriate holes, insert the fasteners and wire things up.
