Design Challenges
Design Challenges
Forum Seeking your Feedback on Proposed Kit and Prizes for Single Pair Ethernet Challenge
  • Replies 33 replies
  • Subscribers 12 subscribers
  • Views 4213 views
  • experimenting with single pair ethernet
  • member discussion
rscasny
rscasny over 1 year ago
Hi All.
In July I had a discussion with you regarding my plans to launch an Experimenting with Single Pair Ethernet Challenge.
Back then, I just began thinking about the challenge's kit and was interested in getting your input on what a kit could include. I took that feedback and began looking at the kit and the costs, etc.
In this follow up discussion, I am listing below a kit I would like you to take a look at. BEfore I get into the kit, let me talk about the challenge a bit more.
There are a couple important things to achieve in this challenge.
I don't believe we have had a sponsored activity on Single Pair Ethernet (SPE). So, one important thing is to begin exploring and learning about SPE in this challenge. Unfortunately, costs and/or budgets limit what I can offer in the kit, but I hope what we can afford to offer is worth your time to participate.
Since this challenge is primarily sponsored (paid for) by Molex, we would like you to use the Molex parts in whatever you do.
So here's the kit below.
Take a look and vote in the polls or leave a comment. Thanks.
ANALOG DEVICES EVAL-ADIN1110EBZ Evaluation Kit, ADIN1110CCPZ, Ethernet Physical Layer Device, Ethernet MAC-PHY, 10BASE-T1L
User Guide
ANALOG DEVICES EVAL-ADIN1100EBZ Evaluation Kit, ADIN1100CCPZ, Ethernet Physical Layer Device, 10BASE-T1
User Guide
RASPBERRY-PI RPI4-MODBP-4GB SBC, Raspberry Pi4 B 4GB, BCM2711, ARM Cortex-A72, 4GB RAM
Datasheet
ANALOG DEVICES EVAL-CN0575-RPIZ Evaluation Board, LTC9111IDE#TRPBF, Raspberry Pi Platform
User Guide
DIGILENT 410-221 Pmod TMP2: Temperature Sensor
Datasheet
MOLEX 2209570104 Ethernet Cable, SPE Plug to SPE Plug, STP (Shielded Twisted Pair), Green, 1 m, 3.3 ft
and
MOLEX 2209570108 Ethernet Cable, SPE Plug to SPE Plug, STP (Shielded Twisted Pair), Green, 5 m, 16.4 ft
Datasheet (1m)
Datasheet (5m)
MOLEX 2209570001 Modular Connector, SPE Jack, 1 x 1 (Port), 2P2C, IP20, Through Hole Mount
Datasheet
MOLEX 2209570002 Modular Connector, SPE Jack, 1 x 1 (Port), 2P2C, IP20, Through Hole Mount
Datasheet
Should anything be added to this kit?
None of our challenges offer a totally comprehensive kit. Hence, no kit is perfect. But given the kit we are proposing, is there anything you feel should be added? If it is something that doesn't bust the budget, we would consider adding it to the kit.
Proposed Prizes
Grand Prize
MULTICOMP PRO MP720025 US Digital Oscilloscope, 4 Analog, 100 MHz, 1 GSPS, 40 Mpts, 3.5 ns
Runner Up Prize
MULTICOMP PRO MP720011 US Digital Oscilloscope, 2 Analog, 100 MHz, 1 GSPS, 10 kpts, 3.5 ns
Finisher Prize
MULTICOMP PRO MP720782 US Oscilloscope, 2 Channel, 70 MHz, 250 MSPS, 6 kpts, 5 ns
  • rscasny
    rscasny over 1 year ago in reply to JWx
    I'll ask analog devices the week
  • rscasny
    I'll ask analog devices the week.
  • JWx
    JWx over 1 year ago in reply to rscasny
    maybe this one (probably needs confirmation because public datasheet is really sparse):
    https://www.tdk-electronics.tdk.com/en/3250586/design-support/epcos-sample-kits/spe/spe/3250602
    or the second one from:
    https://product.tdk.com/en/techlibrary/applicationnote/single-pair-ethernet.html
    but is seems to be really simple - maybe some inductors/common mode chokes would do without greatly increasing kit's price, and the participants would have a chance to build them themselves
  • jc2048
    jc2048 over 1 year ago in reply to kmikemoo
    Do you think that it might be better to have the PoE PSE combined with the media converter, rather than patching the bits together? ADI offer this board, which appears to combine both functions:
    https://www.analog.com/en/resources/evaluation-hardware-and-software/evaluation-boards-kits/demo-adin1100d2z.html#eb-overview
    BTW this isn't a recommendation. I know so little about all this I had to look up the difference between T1L and T1S just now.
    Edit: forget that. It doesn't help because it takes away the access to a processor for doing something stand-alone.
  • JWx
    that's the problem kmikemoo  have mentioned - power coupler is often mentioned in the docs but without a part number (but sometimes with a schematics of the simplest version)...
  • JWx
    JWx over 1 year ago in reply to kmikemoo
    I think that cable connectors are doubled as screwed terminal blocks in many cases, allowing for more permanent (but easier to prepare) connection - to be seen if in components in the kit...
  • kmikemoo
    kmikemoo over 1 year ago
    I would like to see some male connectors added.  I get that there will be cables provided, but let's go crazy and (maybe) make our own, longer cables.  If I'm installing this in my plant, I want to know if I can use existing wiring - even if "less than compliant" in my application.
  • kmikemoo
    kmikemoo over 1 year ago in reply to rscasny
     rscasny I've had no luck in finding a part number.  The part in question is the one circled in the picture.
    I have seen diagrams that have it and diagrams that don't.  It is often referenced in conjunction with the CN0575 and I believe it is the power supply for the CM0575/Pi combination.  Otherwise, the Pi would need a separate power supply - defeating the SPoE / PoDL feature.
    And... I could be wrong.  I've dug into this, both SPE and looking for this coupler, a few times and this is what I have concluded. <Insert shrug emoji here>
  • rscasny
    I didn't see the part number for the coupler. Could you point it out?
  • scottiebabe
    scottiebabe over 1 year ago
    Very cool, great opportunity to experiment with SPE.
