Design Challenges
Design Challenges
Forum Seeking Feedback for Kit on Upcoming LED Design Challenge
  • Blogs
  • Replies 24 replies
  • Subscribers 15 subscribers
  • Views 2874 views
  • design challenge
  • würth
  • IC-LED
rscasny
rscasny over 1 year ago
imageHi All.
As the new year moves on, so does element14's scheduling of new Design Challenges. That's what I want to talk to you about today. Specifically, an LED-focuses challenge.
We haven't done much with lighting/LEDs (although Tariq may have when he managed Project14), but I have a sponsor who is interested in such a challenge. So, I'm exploring here how to make it work, both in terms of your interest in this activity, a propose challenge kit, as well as any theme it would cover.
In this discussion, I wanted to do a few things. For starters, to share with you the parts the challenge's sponsor would like to see in the design. Now, that does not limit us from adding parts to the kit. The next thing I want to do was flesh out the challenge's objective. Let me start with the parts. There's just a few of them:
1315050930002 LED, AlInGaP, InGaN, Red, Green, Blue, SMD, 120 °, Round, R 13mA, G 13mA, B 13mA
More Info
1313210530000 LED, AlInGaP, InGaN, Red, Green, Blue, SMD, 120 °, Dome, R 5.5mA, G 5.5mA, B 5.5mA
More Info
1312020030000 LED, AlInGaP, InGaN, Red, Green, Blue, SMD, 120 °, Square, R 5.5mA, G 5.5mA, B 5.5mA
More Info
1312121320437 LED, AlInGaP, InGaN, Red, Green, Blue, SMD, 110 °, Square, R 20mA, G 20mA, B 20mA
More Info
Click on this link to see the manufacturer's documentation for these products.
Here's a dual wire diagram for the product:
So, the above is kind of bare bones. I expect that there will be much more in the kit depending what the challengers would like to do. Now, what element14 would also include in the challenger's kit would depend on what you would want to do. A few random thoughts about it are:
  • Creative Lighting
  • LED Indication
  • LED Alerting
  • LED Alarming
The sponsor calls out what they see as the leading applications of their LEDS. They are:
  • Appliances
  • Industrial Control
  • Smart Lighting
  • Gaming
  • Decorative Lighting
Now is a good time for a poll:
So, I've offered a lot of information to chew about.
Just for myself, I think it would be fun to do something along the lines of Creative or Decorative Lighting. I would need to include prototyping gear, as well as a kit of support components. Enclosures I would probably not provide since many of you have 3D printers and have that capability; I also would probably not offer any test equipment as part of the kit, but you can always wish for it! I'd probably like to see some PCBs designed and built, with whatever solution you have available.
Now, if you were more interested in something more practical, the designs would require a larger and probably more extensive kit. I'm thinking industrial control panels etc.
Thanks you for participating in the element14 Communities activities.
What Do you think? If you have the time, please vote in my poll and/or leave a comment.
  • beacon_dave
    beacon_dave 3 months ago in reply to Emmanueldio
    Probably something like this:
    https://www.xvxchannel.com/en-gb/collections/keycaps/products/spider-web-imd-keycap
  • Emmanueldio
    Emmanueldio 3 months ago in reply to balajivan1995
    Hello dear, this like is broken said 404 https://www.xvxchannel.com/collections/keycaps/products/xvx-spider-web-version-pattern-oem-profile-imd-tech-keycap-set
    I really want to check this out.
  • beacon_dave
    beacon_dave over 1 year ago in reply to scottiebabe
    Dangly earrings then ?  Slight smile
    3V 50mAh Lithium Pin Cell Battery - CR435
    https://www.farnell.com/datasheets/650640.pdf
  • scottiebabe
    scottiebabe over 1 year ago in reply to beacon_dave
    I have seen cr435 fishing lure batteries
  • beacon_dave
    You mean you haven't got the 12V eJewel power outlet behind the ears yet ? Shrug
    Perhaps could work them into some sort of small bag which has enough room for the power pack.
    Use them as an alternative to rhinestones to add a bit of animated sparkle.
    Could perhaps still do jewellery in the form of a brooch, which then attaches to the outside of the bag and clips onto a power source inside the bag.
    The smaller size would probably work quite well for edge highlighting or for decorative flourishes.
    The square form factor might work against some applications as it is often easier to drill or punch a clean round hole than a square one.
  • rsc
    rsc over 1 year ago
    These seem extremely similar to Adafruit NeoPixel or DotStar 5050 LEDs
  • scottiebabe
    Sadly the quiescent current on most addressable LEDs is pitiful, a whole mA.
    dougw over 1 year ago
    I can think of a cool application for the  unusual 1313210530000 part, but it needs over 150 devices.
  • embeddedguy
    embeddedguy over 1 year ago
    It's a good topic. Better would be to design some PCB based on these parts of LEDs. There are many things one can do with these LEDs both in software and hardware.
    Some example application would be like
    >> Air Q indicator
    >> Smart traffic control indicator
    >> Night room for kids with stars shining
    >> A flying kite for the night (hahaha)
    And many more.
  • balajivan1995
    balajivan1995 over 1 year ago
    Something like this.
    www.xvxchannel.com/.../xvx-spider-web-version-pattern-oem-profile-imd-tech-keycap-set
