Design Challenges
Design Challenges
Forum Where can I find electronic circuits classified by “difficulty level”?
  • Blogs
  • Replies 7 replies
  • Subscribers 9 subscribers
  • Views 766 views
  • student
  • experimenting
  • Design
  • electronics
AlissonOliveira17
AlissonOliveira17 10 months ago
Greetings. I am a researcher currently developing a study on the measurement of difficulty/complexity in electronic circuits. I am looking for books, scientific articles, instructional materials, or datasets that present sets of electronic circuits accompanied by some indication of difficulty, complexity level, or pedagogical classification, even if such indication is subjective or approximate. Any reference would be welcome, including classic textbooks, lecture notes, datasets, academic repositories, or materials used in technical or university-level education. If you are aware of works that organize circuits by difficulty level, or that could be used as a basis for comparative analysis, I would greatly appreciate your help and recommendations. On my ResearchGate profile, I have published some works on complexity measurement in other domains, such as industrial property patents and C programming language source code, which may help contextualize my research approach. Thank you in advance for any help or references you may be able to share.
  • rsc
    rsc 10 months ago
    I would agree to what doug said, and add the fact that difficulty is a relative measure that assumes a baseline understanding.  The more experienced or skilled a person is in a particular subject, the less difficult projects in that subject will be.
    dougw 10 months ago
    I'm not sure what you are referring to when you say complexity or difficulty. Schematics are just simple diagrams showing what components are connected together. In that sense complexity is mostly related to how many connections are made in the schematic.
    If you are referring to how hard it is to understand what a circuit is supposed to do, it could be approximated by determining how much reading and study is required to understand each component and its interaction with other components. One way to characterize this is how many pages of datasheet are needed to explain every component.
    If you are talking about the complexity of circuit boards, their complexity is proportional to several factors:
    • The denser the component layout, the harder it is to achieve
    • The higher the frequencies on the board are, the harder it is to calculate parasitic influences of the board and other components (which are seldom detailed in datasheets)
    • The more power required in the circuit the harder it is to manage thermal performance
    etc.
    It is often hard to separate software from the discussion of circuit complexity, since a lot of circuit functions are actually performed in software these days.
    Some poorly documented circuits require a lot of knowledge and experience to decipher. For well documented circuits the size of the description document is an indicator of complexity.
  • AlissonOliveira17
    Hello, Here is my researchGate link: www.researchgate.net/.../Alisson-Oliveira-17
    michaelkellett 10 months ago in reply to cstanton
    Thanks  cstanton  - I found  a couple of papers in English by working back from that link.
  • cstanton
    cstanton 10 months ago in reply to michaelkellett
    michaelkellett said:
    I tried to look that up but didn't get anywhere - entering Alisson Oliveira into the ResearchGate search bar does not lead any where useful.
    www.researchgate.net/.../Alisson-Oliveira-Lab-3 for context.
    Edit: there's a better link here: RE: Where can I find electronic circuits classified by “difficulty level”?
    Some links to actual papers in English would be more helpful.
    I'm interested that you appear to associate complexity and difficulty without a definition when the two are at best loosely correlated and both are very context dependent.
    It would be interesting if you were to explain the purpose of your research in rather more detail.
  • olivia_49
    olivia_49 10 months ago
    You could look at textbooks like The Art of Electronics or Microelectronic Circuits, or university lab exercises and MIT OpenCourseWare, which often indicate circuit difficulty. Open-source sites like CircuitVerse sometimes tag circuits by complexity, too.
