Design Challenges
Design Challenges
Forum Circuit Design for Rf to usb adapter
  • Blogs
  • Subscribers 6 subscribers
  • Views 1540 views
  • rf circuit design
  • analog signal analysis
  • digital signal processing
alikhan968
alikhan968 over 9 years ago
Hey guys ...Can someone help me to build a Coaxial cable to USB adapter by which i can get my Analog TV signal into laptop..
Below is the link which i actually want to make...Any circuit diagram or suggestion will be helpful.Thanks
Universal Coax RCA Video Audio To USB Converter Digital Video Recorder
  • Workshopshed
    Workshopshed over 9 years ago
    In principle conversion of video is a case of capturing lots of frames much faster.
    Here's some more links that might help.
    How Does a Video Capture Card Work? | It Still Works
    https://www.maximintegrated.com/en/app-notes/index.mvp/id/1184
    It is an advanced project and you do need to understand about how video signals and high speed data transfer.
    You might also want to consider FPGA, again an advanced technique but very good and handling lots of data quickly.
    https://www.altera.com/en_US/pdfs/literature/wp/wp-video0306.pdf
    There are plenty of solutions to this problem and with a bit of research and hard work you should be able to get something that captures to the laptop.
  • alikhan968
    alikhan968 over 9 years ago in reply to Workshopshed
    Thanks clark for response...I read the whole website and I conclude that this is only image capture which capture or grab our desired picture from video...If i am right then i want to clarify that i want to transmit my analog tv video signal to my laptop so if you kindly help me ..It's really very helpful..
  • Workshopshed
    Sounds like you need a video capture circuit
    MkI Video digitiser circuit description
