Design Challenges
Design Challenges
Forum Proposing the Feasibility of a Circuit Design Challenge-- What Do You Think?
  • Replies 17 replies
  • Subscribers 17 subscribers
  • Views 3096 views
rscasny
rscasny over 9 years ago
All of our design challenges to date have been what I call "system design" challenges. What I mean by that is element14 gives the challengers a kit of a few pre-built dev boards that are designed for rapid prototyping. The challenger use the boards to build a prototyped system. I think this approach works quite well to build something quickly in the 11 weeks that we give the challengers to build their projects.
But unlike some other project building sites out there, element14 is a community of engineers, not just makers, or hobbyists. Part of our mission is to promote the whole electronic design process. So, we want to offer something that promotes sound electronic circuit design.
This I mentioned to my bosses at element14 the possibility of offering a "circuit" design challenge. So, the goal of this challenge would be to design a circuit -- say, a switched-mode power supply -- with certain specifications. My guess is that the "kit" would include a tray of board-level components -- resistors, caps, inductors, diodes, MOSFETs, et. al -- pcb board, soldering tools, and a piece of test equipment (i.e., o'scope).
The deliverable of this design challenge would be a circuit soldered up on the pcb board and functioning within specs. Additional functionality would be given extra points. Of course, there would be prizes. The panel of jusges would probably be technology educators or academics; individuals who understood basic circuit design.
The required blogs would focus on how you designed the circuit, circuit analysis, why you made the decision choices that you made? What resources did you use to help and/or improve your circuit design? How you limited component count? How you dealt with a limited pcb board size?
The idea would need to be fleshed out some more.
But I personally want to build on the rapid prototyping concept of a design challenge to one that focuses on basic and complex circuit design.
Okay, that's my proposal.
What do you think of it?  How many would be interested in participating in this kind of design challenge?
If you were interested, how would you improve on the concept I have presented?
Randall Scasny
  • ipv1
    ipv1 over 9 years ago
    Great Idea. If you want to devitate from DCs and RT+, then may I suggest a challenge about blogging directly.
    e.g. Design and explain the creation of a simple wireless sensor network using BLE 5.0 given the ST Iot Design Kit.
    e.g. Teach us about, making a smart battery backup for a single board computer given the TI BQ25570 EVM
    e.g. Create and demonstrate your design for a home security system using IBM Watson and the NXP FRDM K64F IoT Kit
    This focuses on the documentation of a small, medium or large project from the view point of a designer. Most of us already have a bag of these projects or atleast have though up or torndown a related product. Instead of making a teardown, it would be a "build-up challnge" and with the view point of the designer. Do an LTSpice simulation, select a few parts, make a board, use stencils for SMD, learn about something new in the process. The idea is to design something in electronics but also not something that you normally would not make cause it may be cheaper to get it from home depot or something.
    Ofcourse I may be totally off my rocker since I do all that around four times a year... every year. image
    dougw over 9 years ago in reply to tans
    Well put - I think you nailed some common issues that explain the view of many engineers. I have always struggled with my need for perfection or frustration with having to accept an inferior solution - even in home projects, but I've wrestled it down to a manageable level of debilitation. I can see how a hobby in a different field gets away from work frustrations. Sports and entertainment are good for that too.
    As far as equipment and lack of resources - definitely big factors - I still don't want to tackle BGAs despite all the hobbyists who have found cheap ways to deal with them. On the test equipment side, e14 road tests are really helping to build my instrumentation arsenal.
    I like your idea of making educational design blogs - there are so many little tricks that engineers use to increase productivity or improve performance or reduce costs oe ensure success that just never get captured.
    dougw over 9 years ago in reply to gecoz
    Nicely articulate analysis - your description of work priorities really resonates. There are always many drawbacks and frustrations with any job which you have little control over or you have to make big sacrifices and accommodations to overcome. With projects at home you have full control to maximize enjoyment and reward.
  • tans
    tans over 9 years ago in reply to dougw
    Before I was an electronics engineer, electronics was my hobby. Now that I spend 40 or 50 hours a week doing it for a living, it's really hard to motivate myself to spend my limited free time doing the exact same thing. Hobbies generally help us get some space from work - that's why your computer scientists and programmers do it. It's far enough away from their main occupation.
    I also find it's hard to do things "properly", and it irritates me. I can't afford to have boards populated just for a home project, so I end up with designs that are a real pain to assemble. Those BGAs and QFNs don't solder themselves. Good equipment is expensive. I would really like to spend some time designing some spectrum analyzer components, but I don't have the test equipment to actually design/build/tune them.
    As for the challenge idea itself - it would be hard to balance it. Design engineers would absolutely dominate it. Taking your SMPS example; any experienced electronics engineer could design, simulate, and lay out a SMPS on a board in <1 day and be >95% confident it would just work. It would be an interesting learning exercise for others to read, though. Maybe you could base the challenge around the educational value of the submission? Instead of "Cout = this", have "Now, to select the output capacitors we have to consider X, Y and Z...."
  • gecoz
    gecoz over 9 years ago in reply to dougw
    I also noticed the same, but I find it kind of "normal". I believe the reason why hobbies and day job usually don't mix well together is the difference in the "driving force" behind them. An hobby is fuelled by passion and love: you want to design "the best" for yourself and you take lots of pride and joy from what you achieve (even when what you achieved is not actually the best possible result). At work, business rules very often force you to accept tough compromises you would not normally make if it was something done as hobby. This is because at work, you are often asked to design something that needs only to be "good enough" to do the job required, so that you can meet project deadlines while remaining within budget, resources that are very limited if you want to make a business successful. On the countrary, with your hobbies, time and money are (almost) never a show-stopper for your pet projects. I personally find switching between those two, almost opposite, approaches to design very hard (disclaimer: I admittedly suffer from the "reinvent-the-wheel" syndrom when it comes to my hobbies image).
    dougw over 9 years ago in reply to DAB
    I have to admit I know lots of engineers and students who do not indulge in electronics as a hobby, although I have no idea why not. In fact I know many more technicians, technologists, computer scientists and programmers who do electronics as a hobby than engineers. I know many engineers have lots of equipment and CAD stations at home that almost never gets used.
    Generally if you are good at something it pre-disposes you to like doing it, so why wouldn't you want to do it as a hobby?
    Having a complementary hobby can make you better and more successful at your day job, so how come it isn't more popular?.
    Maybe there is a segment that values Netflix and social media more than other hobbies, but I think there is potential in trying to motivate more engineers as well as everyone else to participate in electronics as a hobby.
    DAB over 9 years ago
    Hi Randall,
    Your idea would be perfect for the progressive type of challenge I suggested last year.
    Basically, you make the participants earn the toys piecemeal by showing they have knowledge of the process and are willing work for the good stuff.
    I agree with Andy about this not being something that day job engineers would want to do, but to me that is kind of the point.  You do not want "real" engineers involved except as judges and mentors.
    I would get a couple of volunteers who come in at the end of each partial challenge to go over the process, assess the presentations, show off the good ones, and then give the challengers another week for rework and resubmittal.
    Those that pass go to the next part of the challenge.
    Now, if you are going to make the work this hard, you need some really cool prizes as a reward, but I think you could turn this approach into an excellent learning and mentoring challenge.
    I would be happy to work with you on setting up a series of "beginning" steps, where we can introduce the challengers to the process, identify the key issues each week, and then let them go off and put their first entries together.
    I did something similar when I put a CMMI compliant systems/software engineering training course together about twenty years ago.
    You show them what to do, give them an exercise where they try to do it, then you review and discuss, do clean up and get everyone still interested a chance to move onto the next phase.
    I think this challenge could be a great enticement for students, makers and newbies.
    Just a thought,
  • rscasny
    Thanks everyone for your feedback.
    RParkerE
    Workshopshed
    rsc
    mcb1
    dougw
    fvan
    michaelkellett
    rachaelp
    I should say that the reasons I had proposed this was to (a) involve current and "quiet" community members who are interested in electronics in another way and (b) involve kit suppliers who don't normally sponsor our regular design challenges such as passives, discretes, etc. But, of course, if we were to offer a Circuit Challenge, it needs to be something that is fun and rewarding for our members, which is more important than anything else.
    After reading your comments, you all gave some great feedback. Just having the challengers design a power supply is probably not that challenging since tons of power supply schematics are available in books, blogs, schools, etc. And if someone is going to take the time to design a circuit from scratch, it should be something he or she would have a need for. I like the point system for judging, but maybe I'm getting ahead of myself.
    My hope is to have the challengers design a circuit instead of relying so much on a dev board. Not aonly circuit design skills would be utilized, but also board layout, etc. Or at least require a good portion of the challenge require basic circuit design. Matching an arduino board with a self-designed board would be okay. But I had wanted to give the challengers the microcontrollers, cvap,s resistors, inductors, Qs, etc. and design their circuit.
    You gave a mix of opinions, both plus and minus. But it sounds like the "Design a Lock" example is the way to go.
    Douglas W. had 2 ideas that were along the lines of my thinking; however, he articulated it better than I did in my original post:
    Example 1: suppose the objective is to design a circuit board that contains all the circuitry for a small animatronic puppet. A sponsor might supply a microcontroller chip and a J-Tag programmer (plus IDE) and some small motors. Such a circuit board could be re-used as a platform in any number of automation applications.
    Example 3: perhaps you allow a COTS MCU card to be embedded such as an Arduino Micro - this provides a free development system for software, but the challenge could still require a certain minimum number of interfaces to be part of the custom motherboard.
    Both of these example provide flexibility and a range of design possibilities.
    Perhaps a Circuit challenge needs to pose a problem: Design a circuit to (fill in the blank) using these components (kit that we develop). I also see developing the kit would be a tad bit more challenging.
    I appreciate your time and thoughts.
    Randall
    • Vote Up +9 Vote Down
  • rachaelp
    rachaelp over 9 years ago
    I like the idea too, I think it'll be really interesting to see the different circuit design approaches people take and how they compare with each other. This is something I would definitely find of interest. I'm in agreement with Michael, don't be too prescriptive on the requirements. My way of designing is similar, I do my design straight to schematic and if there are things which are a bit tricky I will create small test PCB's to prove sub circuit concepts before committing them to a larger design. I might have several iterations of the designs before I actually go to the PCB as I analyse things further and refine my ideas. Everybody's different, the results will be better when people are allowed the freedom to work in their own way (within reason).
    Best Regards,
    Rachael
    michaelkellett over 9 years ago
    I like the idea - could even be tempted to contribute - but I think you should try very hard not to be too prescriptive in how the result is presented.
    A working model and some test data is probably the baseline.
    Things like video, simulation, flow charts are all matters of taste - some do and some don't.
    For example, I hardly ever breadboard anything - I usually go from paper to pcb CAD to a board - sometimes there might be some simulation. Other people work in different ways - diversity is good (no evolution without !!).
    @ Andy Clark: I haven't designed a nice audio power amp for ages ....... minimum 2 channels,  100W into 8ohms, 200W into 4, no Doug Self rip offs, no power ICs. image
