Blog Don't forget the windows 05 - something called a library
  • Author Author: hlipka
  • Date Created: 9 Sep 2014 1:41 PM Date Created
  • Views 745 views
  • forget_me_not
  • more_intelligent_home
hlipka
hlipka
9 Sep 2014
After giving up on the existing REST framework I made some progress on the client side of things. I took my basic example and formed a small Java library out of it.
It features:
  • connection to a OpenHAB server by just providing the base address
  • discovery of available pages, starting from the list of sitemaps
  • discovery of sub-pages and items, starting with a page
  • getting notified of updates to items on a single page
  • notifications can be filtered according to the item ID, using regular expressions
I still have some problems with sometimes not getting notifications from items on sub-pages, I need to investigate that. Also, I should properly document the API before I release that library.
Whats next?
Since I want to have a small Android client for my project, I started learning about Android development. I installed Android Studio with all the prerequisites (and some libraries). First step will be to include my library and to get it run under Android. Then I can start trying to get the state of one of the sensors into the widget.
Maybe I should also add a minion somewhere? Would this one look good as logo:
Purple Minion
Or should I wait for another week to choose from?
  • hlipka
    hlipka over 12 years ago in reply to ipv1
    The problem is that when an item appears on multiple pages (e.g. you have one page per room, and one overview page) sometimes notifications about changes to that items are not delivered via the REST API. I already found that when a sitemap is created, the internal name for it (inside of the file) needs to match the name of the file, otherwise changes to the items won't lead to REST notifications.
    It might be that for linked pages the problem is the same, since their name is created at runtime.
  • ipv1
    ipv1 over 12 years ago
    Discuss in detail the problems you are facing. Maybe we can help. Good luck with the ADK.
