Blog Pas Home / Auto start OpenHAB
  • Author Author: verrverr
  • Date Created: 20 Aug 2014 1:06 AM Date Created
  • Views 1303 views
  • forget_me_not
  • pas_home
verrverr
verrverr
20 Aug 2014
Pas Home - Index
Hi, this is my lite script to start OpenHAB daemon at startup
Very usefull command during dev
sudo /etc/init.d/openhab.sh start
sudo /etc/init.d/openhab.sh stop
sudo /etc/init.d/openhab.sh restart
How to
#Transfert the openhab.sh script into /opt/openhab/openhab.sh or directly in /etc/init.d/openhab.sh
sudo cp /opt/openhab/openhab.sh /etc/init.d
# Make sure the script is executable (chmod again).
sudo chmod 777 /etc/init.d/openhab.sh
#At this point you should be able to start/stop/restart using the command
#   sudo /etc/init.d/openhab.sh start
#check its status with the status argument
#   /etc/init.d/openhab.sh status
#and stop it with
#   sudo /etc/init.d/openhab.sh stop
#and restart it with
#   sudo /etc/init.d/openhab.sh restart
# To make the Raspberry Pi use your init script at the right time, one more step is required: running the command
sudo update-rc.d openhab.sh defaults
#sudo update-rc.d -f openhab.sh remove
# This command adds in symbolic links to the /etc/rc.x directories so that the init script is run at the default times. you can see these links if you do
# ls -l /etc/rc?.d/*openhab.sh
openhab.sh script
#!/bin/sh
### BEGIN INIT INFO
# Provides:          openhab
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: OpenHAB Daemon
# Description: Build your smart home in no time!
### END INIT INFO
ROOT_DIR=/opt/openhab
# set path to eclipse folder. If local folder, use '.'; otherwise, use /path/to/eclipse/
eclipsehome="$ROOT_DIR/server";
# set ports for HTTP(S) server
HTTP_PORT=8080
HTTPS_PORT=8443
# get path to equinox jar inside $eclipsehome folder
cp=$(find $eclipsehome -name "org.eclipse.equinox.launcher_*.jar" | sort | tail -1);
# This next line determines what user the script runs as.
# Root generally not recommended but necessary if you are using the Raspberry Pi GPIO from Python.
#USER=root
DAEMON_USER=root
DAEMON_NAME=openhab
DAEMON=/usr/bin/java
DAEMON_ARGS="-Djna.boot.library.path=/usr/lib/jni -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=$HTTP_PORT -Djetty.port.ssl=$HTTPS_PORT -Djetty.home=. -Dlogback.configurationFile=configurations/logback.xml -Dfelix.fileinstall.dir=addons -Djava.library.path=lib -Djava.security.auth.login.config=./etc/login.conf -Dorg.quartz.properties=./etc/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Dfelix.fileinstall.active.level=4 -Djava.awt.headless=true -jar $cp $* -console "
PIDFILE=/var/run/$DAEMON_NAME.pid
. /lib/lsb/init-functions
do_start() {
  log_daemon_msg "Starting system $DAEMON_NAME daemon"
  start-stop-daemon --start --background --pidfile $PIDFILE --make-pidfile --user $DAEMON_USER --chuid $DAEMON_USER --chdir $ROOT_DIR --exec $DAEMON -- $DAEMON_ARGS
  log_end_msg $?
do_stop() {
  log_daemon_msg "Stopping system $DAEMON_NAME daemon"
  start-stop-daemon --stop --pidfile $PIDFILE --retry 10
  log_end_msg $?
case "$1" in
    start|stop)
        do_${1}
    restart|reload|force-reload)
        do_stop
        do_start
    status)
        status_of_proc "$DAEMON_NAME" "$DAEMON" && exit 0 || exit $?
        echo "Usage: /etc/init.d/$DAEMON_NAME {start|stop|restart|status}"
        exit 1
esac
exit 0
openhab.zip
  • ravi_butani
    ravi_butani over 12 years ago
    Thanks @Pascal_martin this really helps me... I need to reboot every time my pi for restart openhab...
  • ravi_butani
