Blog Pas Home / Eagle 7.1.0 Pro First design
  • Author Author: verrverr
  • Date Created: 20 Aug 2014 1:27 AM Date Created
  • Views 2333 views
  • Comments 13 comments
  • forget_me_not
  • pas_home
verrverr
verrverr
20 Aug 2014
Pas Home - Index
In my project I plan to modify an existing circuit because it has too many communication errors with the sensors. In a future blog I will try to see the problem with the oscilloscope. Do you see errors to correct? Will the new scheme all the resistors are essential?
Dans mon projet je planifie de modifier un circuit existant car il a trop d'erreur de communication avec les capteurs. Dans un blog futur je vais essayer de voir le probleme avec l'oscilloscope. Est-ce que vous voyer des erreurs a corriger ? Est-ce que dans le nouveau schema toute les résistances sont essentiel ?
The captor are 1-wire temerature sensor DS18B20+
My current schematic
My proposed new schematic
Use DS2482S-800+ to isolate each sensor communication
Reference schematic
I follow this lesson https://learn.adafruit.com/adafruits-raspberry-pi-lesson-11-ds18b20-temperature-sensing/ds18b20
EagleFile.zip
  • michaelwylie
    michaelwylie over 12 years ago
    I don't see anything physical wrong with the first design. Maybe the code?
  • verrverr
    verrverr over 12 years ago in reply to michaelwylie
    I think the big probleme with first design is the length between the captor and my raspberrypi each sensor have a cable of 20-50 feets long
    I fond a document witch talk about the probleme and possible solution, adding 100ohm. It work great but not with a reliability of 100% near 80-98%
    Guidelines for Reliable Long Line 1-Wire Networks - Tutorial - Maxim
  • michaelwylie
    michaelwylie over 12 years ago in reply to verrverr
    20 - 50 feet!? yeah, that's a little long ...
  • michaelwylie
