Blog Pas Home / Eagle 7.1.0 Pro First design
  • Author Author: verrverr
  • Date Created: 20 Aug 2014 1:27 AM Date Created
  • Views 2329 views
  • Comments 13 comments
  • forget_me_not
  • pas_home
verrverr
verrverr
20 Aug 2014
Pas Home - Index
In my project I plan to modify an existing circuit because it has too many communication errors with the sensors. In a future blog I will try to see the problem with the oscilloscope. Do you see errors to correct? Will the new scheme all the resistors are essential?
Dans mon projet je planifie de modifier un circuit existant car il a trop d'erreur de communication avec les capteurs. Dans un blog futur je vais essayer de voir le probleme avec l'oscilloscope. Est-ce que vous voyer des erreurs a corriger ? Est-ce que dans le nouveau schema toute les résistances sont essentiel ?
The captor are 1-wire temerature sensor DS18B20+
My current schematic
My proposed new schematic
Use DS2482S-800+ to isolate each sensor communication
Reference schematic
I follow this lesson https://learn.adafruit.com/adafruits-raspberry-pi-lesson-11-ds18b20-temperature-sensing/ds18b20
EagleFile.zip
    mcb1 over 12 years ago
    I wondering if the issue is with the on board 3v3 regulator.
    Generally speaking they are much lower current rated than the 5v ones.
    Have you tried sticking a 4700uF or larger across the 3v3 line.?
    Now that you have your scope you could check to see it is 3v3 and that there is no noise on it.
    Is it possible to run your micro on 5v.?
    re level translators
    The general rule with any IC is never apply a voltage to any pin greater than the supply voltage. (unless it's special purpose pin)
  • michaelwylie
    michaelwylie over 12 years ago in reply to mcb1
    That's a good idea. The voltage drop across that much wire could be significant.
  • michaelwylie
    mcb1 over 12 years ago in reply to michaelwylie
    Sorry it was the regulator, but I forgot he was already using a RPi   ...as kipe pointed out.
    Obviously it can't run on 5v ...so yes it needs to run 3v3.
