Blog Pas Home / Home ventilation with RPiSoC
  • Author Author: verrverr
  • Date Created: 1 Sep 2014 12:38 AM Date Created
  • Views 1781 views
  • Comments 7 comments
  • forget_me_not
  • pas_home
verrverr
verrverr
1 Sep 2014
Pas Home - Index
I will use the RPiSoC to control and catch the status of my home ventilation system. Integrate with OpenHAB and my humidity sensor, when i take my shower humidity sensor detect the humidity increase and automatically start the ventilation. I suck in electronics I'm going to need your help.
The plan
The timer
I open the current control and check component.
Its seems simple enough:
      4 wire 12v, GND, LED Control, SW (Switch),
     LM2901DG Chip (From spec 'Designed for use in level detection')
     3 LED
     Push button
     100uf 63v 85°C (Capacitor)
The signal
With the Tektronix oscilloscope i check what happen in SW and LED wire.
SW wire, have continuous 5v DC and when i press control button its drope near 0v and when i release it return to 5v. When signal is reduce to 0v for about 1 second or more the main control unit detect it and start ventilation and switch between each timer state.
What is the name of this transition? Do you know some tutorial links to reproduce this with RPiSoC ?
The LED wire have his voltage between 0v to 10v. Each value indicate a state. Measure voltage between 0v to 5v with RPiSoC its seem very easy with analog port and this sample code https://github.com/EmbeditElectronics/psoc_2_pi/blob/master/API_Python_v_1_1/SAR_ADC_voltmeter.py
But how measure voltage with range 0v-10v? Use a Voltage Dividers? Do you know a good tutorial?
  • kipe
    kipe over 11 years ago in reply to verrverr +1
    Hey. Try with larger resistors, so the affect on the existing circuit won't be that much. Something like 1M and 470k might work...
  • hlipka
    hlipka over 11 years ago
    What you measure for the switch looks like a normal input with a pull-up resistors. You should be able to control that with a transistor (or a small relay if you want to have isolation).
    Are the switches on the panel mechanical?
    mcb1 over 11 years ago
    It seems that the inputs are are 3v3 so you'll need to use a 2:1 ratio on your resistors.
    ie a 10K and 4k7 across the 0-10v will give 0-3v2 at the junction of the two resistors.
    Sparkfun has a tutorial including a handy calculator
    https://learn.sparkfun.com/tutorials/voltage-dividers
    There is another calculator here.
    http://www.raltron.com/cust/tools/voltage_divider.asp
    RPISoC info and examples
    http://embeditelectronics.github.io/psoc_2_pi/examples.html#voltmeter-using-the-16-bit-delta-sigma-adc
    The documentation seems to be all here.
    http://www.cypress.com/psoccreator/
    and the ADC you require
    http://www.cypress.com/?docID=45831
