Blog Pas Home / Week 1 Result, products and softwares learning
  • Author Author: verrverr
  • Date Created: 11 Aug 2014 3:21 AM Date Created
  • Views 984 views
  • forget_me_not
  • pas_home
verrverr
verrverr
11 Aug 2014
Pas Home - Index
This week, like many, I made a little prototype with openHAB and sensors. Here's my recipe and a video
Cette semaine comme beaucoup, j'ai fait un petit proto avec openHAB et les capteurs. Voici ma recette et une video
Here is my installation procedure on my two raspberrypi
Voici ma procédure d'installation sur mes deux raspberrypi
For my first raspberrypi with owfs and node.js
Pour mon premier raspberrypi avec OWFS et node.js
# Step 1 Prepare
- Download RASPBIAN Debian Wheezy
  http://www.raspberrypi.org/downloads/
- Format SD Card with SDFormatter.exe
  https://www.sdcard.org/downloads/formatter_4/eula_windows/
- Write Raspbian with win32diskimager-v0.9-binary
  http://sourceforge.net/projects/win32diskimager/
- Boot raspberrypi and configure setting
  timezone, password, keyboard and internet
- Update raspberrypi
  sudo apt-get update
  sudo apt-get upgrade
  sudo reboot
- Activation de l’I2C (http://innovelectronique.fr/2013/03/02/utilisation-du-bus-i2c-sur-raspberrypi/)
  # Replace 'blacklist i2c-bcm2708' with '#blacklist i2c-bcm2708' in /etc/modprobe.d/raspi-blacklist.conf
  sudo sed -i 's/blacklist i2c-bcm2708/#blacklist i2c-bcm2708/g' /etc/modprobe.d/raspi-blacklist.conf
  # Add 'i2c-dev' in /etc/modules
  sudo sed -i '$ a\i2c-dev' /etc/modules
  sudo reboot
  # Test i2c
  # dmesg | grep i2c
  # ls /dev/i2c*
# Step 2 Install OWFS (http://www.gaggl.com/2013/01/accessing-1-wire-devices-on-raspberry-pi-using-owfs/)
  sudo apt-get install owfs ow-shell
  # Change config
  # Remove fake device
  sudo sed -i 's/server: FAKE/#server: FAKE/g' /etc/owfs.conf
  # Add i2c device
  sudo sed -i '$ a\--i2c=ALL:ALL' /etc/owfs.conf
  # Allow access from a remote device
  sudo sed -i 's/server: port = localhost:4304/server: port = 4304/g' /etc/owfs.conf
  # Restart service
  sudo /etc/init.d/owserver restart
  sudo /etc/init.d/owhttpd restart
  sudo /etc/init.d/owftpd restart
# Step 3 Install nodejs (http://joshondesign.com/2013/10/23/noderpi)
  cd ~
  wget http://nodejs.org/dist/v0.10.28/node-v0.10.28-linux-arm-pi.tar.gz
  tar -xvzf node-v0.10.28-linux-arm-pi.tar.gz
  echo NODE_JS_HOME=/home/pi/node-v0.10.28-linux-arm-pi >> /home/pi/.bash_profile
  sudo sed -i '$ a\PATH=$PATH:$NODE_JS_HOME/bin' /home/pi/.bash_profile
  # reboot or logout login user for bash_profile reload
  sudo reboot
  # Test
  # node --version
# Step 4 Install small web app for led control usint http call from openhab
  # Copier le zip pascalhome_ledcontrol.zip dans /home/pi/pascalhome_ledcontrol.zip
  cd ~
  sudo /home/pi/pascalhome_ledcontrol.zip
  cd /home/pi/ledcontrol
  npm install
  sudo /home/pi/node-v0.10.28-linux-arm-pi/bin/node app.js
  # Test led
  # http://192.168.0.194:3000/ledcontrol?status=ON
  # http://192.168.0.194:3000/ledcontrol?status=OFF
For my second raspberrypi with OpenHAB
Pour mon second raspberrypi avec OpenHAB
# Step 1 Prepare
  sudo apt-get update
  sudo reboot
- Make EnOceanPi Ready
  #Download and extract rpi-serial-console script
  sudo wget https://raw.github.com/lurch/rpi-serial-console/master/rpi-serial-console -O /usr/bin/rpi-serial-console && sudo chmod +x /usr/bin/rpi-serial-console
  sudo rpi-serial-console disable
  sudo reboot
- For gpio addon work ()
  sudo apt-get install libjna-java
# Step 2 Install OpenHab and my demo app
- Install openHAB Core
  sudo wget https://github.com/openhab/openhab/releases/download/v1.5.0/distribution-1.5.0-runtime.zip -O /home/pi/distribution-1.5.0-runtime.zip
  sudo mkdir /opt/openhab
  cd /opt/openhab/
  sudo unzip /home/pi/distribution-1.5.0-runtime.zip
- Installing my demo openHab config
  # Transferer le zip pascalhome_openhab_proto1.zip dans /home/pi/pascalhome_openhab_proto1.zip
  sudo unzip /home/pi/pascalhome_openhab_proto1.zip
- Change openHAB start.sh
  # for encoean append -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0  right after java
  sudo sed -i 's/java /java -Dgnu.io.rxtx.SerialPorts=\/dev\/ttyAMA0 /g' /opt/openhab/start.sh
  # for gpio addon "start.sh" and append -Djna.boot.library.path=/usr/lib/jni right after java
  sudo sed -i 's/java /java -Djna.boot.library.path=\/usr\/lib\/jni /g' /opt/openhab/start.sh
- Start openHAB
  sudo chmod +x start.sh
  sudo ./start.sh
  # Test openhab
  # http://192.168.0.192:8080/openhab.app?sitemap=demo
  #Troubleshooting with gpio after restart openhab
  #If the message Device or resource busy is printed unexport your gpio with next command
  echo 21 > /sys/class/gpio/unexport
  echo 20 > /sys/class/gpio/unexport
  #https://sites.google.com/site/semilleroadt/raspberry-pi-tutorials/gpio
  • verrverr
    verrverr over 12 years ago
    Sorry for the quality of images and video, my lens was dirty.
    Désolé pour la qualité des images et de la vidéo, ma lentille étais sale.
