Blog "Remember me always!" - Part 002
  • Author Author: COMPACT
  • Date Created: 5 Aug 2014 10:48 PM Date Created
  • Views 968 views
  • Comments 5 comments
  • forget_me_not
  • remember_always
COMPACT
COMPACT
5 Aug 2014
An Alternative Universe
When doing some research I found the EnOcean Sensor Kit Manual.
It describes a method to prepare a RPi to get FHEM with EnOcean Sensors up and going.
Very Useful Stuff!
http://www.farnell.com/datasheets/1824742.pdf
  • electronichamsters
    electronichamsters over 12 years ago in reply to vish +1
    Hi Vish, I think this is the procedure: 1) save the addon for enocean binding in the ~/addons folder 2) configure the enOcean binding ~/configurations/openhab.cfg, but look at what others have said about…
  • jpc
    jpc over 12 years ago in reply to vish +1
    Check out some of the other forget_me_not blog entries here on element14 for getting this up and running (on a Pi) if you get stuck. There are a couple of little trouble causing things that have been covered…
  • ipv1
    ipv1 over 12 years ago in reply to vish
    Maybe I am too late, but a bunch of of did various posts on how to use the enocean bindings.
    Hope they help.
    Cheers
    IP
  • jpc
    Check out some of the other forget_me_not blog entries here on element14 for getting this up and running (on a Pi) if you get stuck. There are a couple of little trouble causing things that have been covered and resolved. You need to disable use of /dev/ttyAMA0 in /boot/cmdline.txt and /etc/inittab so that the EnOcean Pi can use it and you need to modify a line in start.sh to allow java to access symbolically linked com ports, such as /dev/ttyAMA0
    Hi Vish,
    2)  configure the enOcean binding ~/configurations/openhab.cfg, but look at what others have said about changes to serial port
    3)  add the item to your /configurations/items/demo.items file per wiki:
    Switch Button_Up () {enocean="{id=00:00:00:00, eep=F6:02:01, channel=B, parameter=I}"}
    Number UG_Flur_Temp "Temperature [%.1f °C]" <temperature> () {enocean="{id=00:00:00:00, eep=A5:02:05, parameter=TEMPERATURE}"}
    4)  Add these items to the sitemap under /configurations/sitemaps/demo.sitemap
  • vish
    vish over 12 years ago
    Anybody found any documents describing how to connect enocean with openHAB? I am still searching.
    I found only this page so far : https://github.com/openhab/openhab/wiki/EnOcean-Binding
    Good find.  Thanks for posting image
