Forum Does anyone have experience with EnOcean STM 300
  • Replies 12 replies
  • Subscribers 7 subscribers
  • Views 4657 views
  • enocean
robertheinze
robertheinze over 11 years ago
Hello!
I am planning to use a motion detector based on EnOcean technology. The available solar powered OEM products using the STM 300 are rather expensive (70€ and more), so I was wondering whether anyone has experience in building your own motion detector Based on STM 300 or if anyone has found a cheaper version of the product.
The idea is have it communicating with a EnOcean Pi modul on a RPi.
Thanks for help.
Regards
Robert
  • robertheinze
    robertheinze over 11 years ago in reply to ravi_butani +1
    HI Ravi, unfortunately I am not enough experienced in hardware design. I want to setup a PIR solar powered (no batty changing action because of maintenance!) sending a signal on movement detection in a…
  • peter.boehm
    peter.boehm over 7 years ago in reply to ravi_butani
    Hi Ravi,
    I am trying to get a STM312 module with firmware STMSEN-868.hex to work with the Openhab binding. Unfortunately the module does not send the values from AD0 - AD2. It sends only a payload FFFFFF0C which does not change if I adjust the voltage at the inputs.
    If I reflash the module with  your special firmware compiled for a STM330 it works for AD0 and AD1. So the module is not dead
    Do you have any idea how to get the module running with the default firmware and the three analog inputs?
    Thanks, Peter
  • Jonathanodfrey
    Jonathanodfrey over 4 years ago
    I think this may help you https://create.vista.com/colors/color-names/
